Page 2 of 2 FirstFirst 12
Results 51 to 65 of 65
Like Tree22Likes
Thread: Stones 'n stuff I've found in coffee...
  1. #51
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,281
    Quote Originally Posted by knastoer View Post
    Do you sort through your beans to make sure there are no sticks, stones or other items that you don't want in your grinder?
    If you do, did you ever find anything - or have you had the misfortune that your grinder found it first?
    I always check green beans prior to and after roasting, in 10 years I've found a couple of small stones, never had one go through the grinder.
    Have never found anything foreign in store bought beans, I believe commercial roaster put all of their beans through a destoner.
  2. #52
    Dec 2004
    Earth!
    15,106
    Not a problem! It helps knowing who posted in such a thread and any likely wording of its' title to help narrow the results down with the search engine. Both of which only come with time.
    Java "Time to what?" phile
    Toys! I must have new toys!!!
  3. #53
    Aug 2008
    Millthorpe NSW
    2,008
    I have a little home-made destoner … works a treat. Every roasted batch goes through it. As you can see - it works!
    This is about 3 years worth…
    Dimal likes this.
  4. #54
    Jul 2008
    Gold Coast
    110
    I like, have you got any details on what goes into making that?
  5. #55
    Jun 2009
    Moonta SA.
    6,281
    Quote Originally Posted by DesigningByCoffee View Post
    Obviously your destoner works better than my eyes.
    I sometimes wonder how many get through and get ground with the coffee, the stones I have found have been of soft material, doubt they would have damaged the burrs anyway.
    Regardless it's good to remove them, you only need a small piece of granite or metal and its goodby burrs.
  6. #56
    May 2007
    Perth, Western Australia
    3,139
    Recently if heard an agonising noise emanating from my Baratza Preciso filter grinder, sadly a square shaped piece of white quartz had snuck through my screening process and lodged itself in the blades and seized the grinder.
    After removing the offending piece of quartz I discovered that the gears driving the blades had been stripped, I decided to cut my losses instead of spending money on repairing it and got a new Baratza Encore which is doing a great job!!
    Henceforth I have been studiously checking my roasts before bagging them!
  7. #57
    Aug 2008
    Millthorpe NSW
    2,008
    Quote Originally Posted by Hipsi View Post
    Hi Hipsi
    It was just a few lengths of poly and some fittings from Bunnings, plus a paint bucket from the same.
    The exotic looking airflow adjuster with metal handle is now unnecessary (I originally intended to use it with a full strength vac) as I found an adjustable suction vac come council cleanup time
    There are some more detailed photos in my album…
    http://coffeesnobs.com.au/members/de...de-stoner.html
    It has certainly earned its keep - especially when people started buying my beans!
    Cheers Matt
    Dimal and matth3wh like this.
  8. #58
    Jul 2008
    Gold Coast
    110
    Cheers Matt
    I can certainly imagine it would do. Now call me slow, or Queenslander (if the shoe fits...) but picture it working by sucking the beans up from the tray, into the bucket, and leaving the stones behind. Is that how it works or am I way off? if that's the case, do you lose many beans to the vacuum?
  9. #59
    Aug 2008
    Millthorpe NSW
    2,008
    It is a little hard to picture!
    You adjust the suck of the vac so that the beans are only just being lifted up out of the mesh tray by the low pressure in the bucket. They go up and drop into the bucket, at which point they are so far away from where the vac entry pipe is that there’s no chance of them being sucked into the vac.
    And yes, as the stones are smaller, heavier and denser they stay in the tray.
  10. #60
    Jul 2008
    Gold Coast
    110
    Okay, so I wasn't too far from the mark with what I was imagining then. Okay, off to find a variable vac then!
  11. #61
    Aug 2008
    Millthorpe NSW
    2,008
    If all you have is a normal vac you can just keep drilling some holes, say 6mm, in the entry pipe to the bucket. You’ll notice the bean lift-off slowing each time. It won’t take too many holes, so go slowly - you can’t really take holes away!
  12. #62
    16,276
    That's what Duct Tape is for...
    DesigningByCoffee and Yelta like this.
  13. #63
    Jan 2018
    51
    My first find! Made me feel good, somehow...
    Andy, DesigningByCoffee and Dimal like this.
  14. #64
    Senior Member GrahamK's Avatar
    Jun 2009
    Ormiston - Brisbane
    532
    Peaberry imitating a Nasty Stone or Nasty Stone imitating a Peaberry?Bad Stone2.jpg
  15. #65
    Jun 2009
    Moonta SA.
    6,281
    Behmor Coffee Roaster
    As the tape on the bottom of my cooler will attest, holes drilled in wrong place, wonderful stuff is duct tape.
  1. international stones in my coffee
    By steven_cox in forum General Coffee Related...
    Last Post: 2nd November 2012, 12:14 AM
  2. Stones in your coffee?
    By darrend in forum General Coffee Related...
    Last Post: 11th September 2012, 08:43 PM
  3. Coffee and stones
    By micstone in forum Grinders
    Last Post: 17th April 2007, 03:06 PM
