Page 2 of 2 FirstFirst 12
Results 51 to 59 of 59
Like Tree5Likes
Thread: UPDATED 12/11/2013 - Popper Roasting - Tips, Tricks & Mods
  1. #51
    Senior Member deegee's Avatar
    Sep 2012
    Brisbane Southside
    315
    Re PWM
    G'day deegee... Probably only requires a change to the voltage scaling into the PWM control circuit. If you could send me a copy of the circuit being used, or a link to it, I might be able to make a couple of suggestions; should you wish to continue pursuing the option of PWM Control of the fan speed. It's an ideal method to use for this purpose, probably down to about 20% of the fan's nominal full speed...Mal.
    G'day Mal. You're probably right about that. The output is controlled by a 10K pot. Over the full range of the pot, it takes the fan from full speed down to almost stalled. This is much more reduction than I need, so only a quarter of a turn of the knob is usable in practice.
    I only need to reduce the speed to about 60% at most, for my application. Maybe if I measure the resistance of the original pot over the "useable section" then replace it with a pot about that value, I may get the reduction that I need, but spread over a full turn of the knob. Your thoughts ???
    I don't have a circuit, or a link to one, and some of the components on the board have no markings whatsoever, so their values are a mystery. I suspect that trying to draw a circuit would be an exercise in frustration. At this time I'm more inclined to take the 'seat of the pants' approach.
    Cheers, deegee.
  2. #52
    Sep 2012
    Brisbane Southside
    315
    Hello Paco,
    I thought that there were more pics in this thread showing a popper with the thermocouple probe and digital thermometer, but they must be in other threads. Sorry, I should rectify that.
    "Temperature's what's important to monitor when you do a profile"
    Yes it is - but I like to establish a pattern for my roasts based on regular voltage increases to achieve the temp profile that I want.
    That way I don't have watch the temp every second of the roast, with my hand poised over the knob, making adjustments on the fly.
    I have a pattern for my preferred profile for most beans, but I also have one longer slower roasts, & another for shorter faster roasts.
    Using these, I choose my start voltage and increase it at one minute intervals to get the required profile.
    That's the main reason why I added the voltmeters.
    "I was hoping you'd draw up a sketch with values"
    I would, but some components have no markings, & others would have to be removed from the board to be able to read them.
    These things are as cheap as chips. If I was in your situation I would buy one and try it on 120V. If they work - that's great, if not, you can dismantle and measure values, then maybe modify it if needed. If it's a write-off, its only a few bucks.
    One of them from ebay seller "sitedv88" Item SKU: 14_S000114008967 specifies :- Voltage 110 - 220v Voltage control 50 - 220v.
  3. #53
    16,204
    Quote Originally Posted by deegee View Post
    Yes mate...
    That's the general idea. Not all that complicated....
    Sep 2012
    Brisbane Southside
    315
    Thanks Mal, I'll give it a try, but probably not 'til later this week.
    Cheers, Deegee.
  5. #55
    Sep 2014
    sydney
    81
    Here's a good article for some to read
    http://ineedcoffee.com/popper-crop-c...pcorn-poppers/
  6. #56
    Aug 2014
    6
    Here's an update. I found an eBay link deleted per http://coffeesnobs.com.au/general-ne...icy-rules.html AC 110v 220V 2000W SCR Voltage Regulator on eBay for just USD$5.00 but I ended up getting the much-recommended Harbor Freight Router Speed Control instead. I figure the time and money I would have spent putting the cheap SCR board in a box would have cost me more than this reasonably priced, self-contained unit. It was on sale for $19.99 and with the 20% OFF coupon it cost just USD$17.40 with the tax. And it has a 90-day no-questions-asked return policy on it. You don't get anything close to that on eBay. There are many posts on forums about using this little workhorse for coffee roasting, beer brew-kettle controller, and many use it for controlling stage lighting. The last 2 uses require adding a hefty heatsink to the metal back-plate, and even for coffee roasting that is advisable. It gets hot to the touch--3 seconds max finger contact--so I will add a heatsink to prolong the life of the SCR. It is designed for the short bursts that you'd use for a router, not extended minutes at a time like you'd use for coffee roasting. So far it works great. I have drastically reduced the temperature of an 1100W popper so I can get long roast times. I put the switch on direct power until the first crack so this doesn't tax the SCR at all, and then switch over to variable for the rest of the roast period.
    I still have to rewire the fan so I can power it separately from a DC supply. I thought of separating out the motor rectifier circuit and achieving a constant 30V using zener diodes in series to keep it down to one cord, but it won't work with an SCR because it varies the duty cycle, not the amplitude. I have a Variac buried in a mountain of boxes and that would work, but the sheer weight and bulk of it defeats the purpose. A separate power supply with a jack would still be quite compact.
    Last edited by Javaphile; 25th September 2014 at 12:29 PM. Reason: eBay link(s) removed
  7. #57
    Aug 2014
    6
    Thanks for that link. It is another reference to add to my collection. It seems that all those poppers are discontinued, and about half of them are the screen-on-the-bottom type which require modification. I started a thread on currently available poppers that met the spiral-vent criterion, years ago at Sweet Maria's: List of Current Air Popcorn Poppers for Coffee Roasting and only recently visited it since I never received email notifications of posts. It has gotten a life of its own and there are a number of poppers users recommend along with tips on various mods, some dangerous. The only 2 that are currently available at a REASONABLE price are:
    West Bend 82416 Air Crazy 3.5 Quart Corn Popper
    This is probably the best choice in a popper because it is widely available at a deep discount off the $29.99 MSRP and is widely used for coffee roasting.
    and:
    Kitchen Gourmet model B-32B [1200W] from Walgreen's
    Cannot find online. This is the one I got Dec. 30, 2010. $7.99 ($9.99) on sale. $8.77 total. They seem to be only available during the Christmas season.
  8. #58
    Sep 2014
    sydney
    81
    Hi All,
    Wanted to share some data around some poppers I have been testing. Since I am new to roasting with a Popper (couple of weeks now), thought it would be good to share what i have done so other people can learn from my experience.
    Today i am showing the difference of two popcorn makers:
    1. Benzer Popcorn Maker - 1200w, 50Hz, 230-240V, Model: 8806 (Brought new at Victoria's Basement) -$30-40 new
    2. Breville Crazy Popper - 1100w-1200w, 50Hz, 230-240V, Model: PCM40 (Brought second hand at Vinnies) - $10.
    Modifications
    1. Benzer Popcorn Maker - Holes drilled in base, side, top (approx. 30-35 drill holes about 3-4mm. Majority on base and lower half and 13 on the top). Since I have had this longer, i know it runs hotter and modified it to give more airflow.
    2. Breville Crazy Popper - None
    Both popcorn makers i have removed the clear plastic lid.
    Pictures attached
    So I have been roasting a single origin - Guatemala La Pacaya Typica
    So without beans this is the sort of temp celcius that i was getting after 2 mins (its only a handheld thermometer as i really only wanted to know how hot/fast the popcorn maker was getting). So apologies if i havent got a fancy graph and its not 100% accurate
    Ambient temp: 21 degrees
    Time (min:sec) Benzer Breville
    00:30 123 C 128 C
    01:00 150 C 139 C
    01:30 182 C 140 C
    02:00 193 C 150 C
    Result 198 C 165 C
    So straight away you can see the Benzer heats up a lot faster.
    So how did it go when i roasted some beans
    Time
    (min:sec)
    Benzer (60g Beans) Breville (60g Beans) Breville (80g Beans)
    00:30 93 C 80 C . (didnt record)
    01:00 145 C 140 C . (didnt record)
    01:30 160 C 168 C . (didnt record)
    02:00 176 C 183 C . (didnt record)
    02:30 190 C 194 C . (didnt record)
    03:00 196 C 193 C . (didnt record)
    03:30 199 C
    1st Crack @ 03:10
    201 C
    1st Crack @ 03:20
    1st Crack @ 03:45
    04:00 216 C 211 C . (didnt record)
    04:30 . (didnt record) 213 C . (didnt record)
    05:00 . (didnt record) . (didnt record) . (didnt record)
    05:30 2nd Crack @ 05:30
    Stopped Roasting
    06:00 . (didnt record) . (didnt record)
    06:30 . (didnt record) . (didnt record)
    07:00 . (didnt record) . (didnt record)
    07:30 . (didnt record) . (didnt record)
    08:00 . (didnt record) . (didnt record)
    08:30 . (didnt record) 2nd Crack @ 08:30
    Stopped Roasting
    09:00 . (didnt record)
    09:30 . (didnt record)
    10:00 . (didnt record)
    10:30 2nd Crack @ 10:15
    Stopped Roasting
    So how did they look and smell.
    • Benzer (60g) - smell was a little burnt but same colour as other beans. Lost 10g of weight post roast
    • Breville (60g) - no burnt smell from beans. Looked clean and same colour as other beans. Lost 10g of weight post roast.
    • Breville (80g) - no burnt smell from beans. Looked clean and same colour as other beans. Lost 14g of weight post roast
    So since i have only roasted, i will need to let you know how they taste in about a week.
    From previous roasts with the Benzer popper it was really nice, but had bitterness through the shot. Much easier with Milk.
    I suspect the Breville with a longer roasting time and a good break between 1st and 2nd crack will be much cleaner and not have bitterness through it.
    Recommendation:
    Well its a little early to say, but i think the Breville crazy popper is much better. Longer roast and no burnt smell from bean.
    I will probably make a call and say the 60g will be the best as the roast was the longest.
    Well i will let you know how it tastes in a week.
    Keep popping on all - Loads of fun :-)
  9. #59
    Sep 2014
    sydney
    81
    Behmor Coffee Roaster
    Just wanted to share an update.
    Since I had been roasting with the benzer a few weeks I thought that was amazing roasted coffee.
    Boy was I wrong. As soon as I opened up and tasted both the breville batches I was blown away. So much nicer.
    So breville popper wins hands down.
    Now on to roasting a few more origins and then into blending them. My world is so much better now :-)
    badbudgie and teemo like this.
  1. Replies: 6
    Last Post: 31st October 2012, 01:03 PM
  2. Bretts BBQ Roasting tips and tricks
    By poundy in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 4th January 2005, 09:01 PM
