Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By MrFreddofrog
Thread: Artisan COM ports
    Aug 2015
    Perth WA
    461
    Artisan COM ports
    Hi there
    Anyone know how to change the COM Artisan sends serial commands to?
    I'm trying to get Artisan to talk to both my Center 304 and Arduino which are on different COM ports.
    Senior Member readeral's Avatar
    Jul 2015
    1,094
    Hey mate, did you work this out?
    When you go to 'Config - Devices' you can select TC4 (which I'm sure you have) but then after you hit 'Ok' it brings up another window 'Serial Ports Configuration' which looks like this:
    Is that what you're looking for? If I needed to, I'd change the values in this ET/BT tab, as the TC4 is a non-Modbus device.
    What problem are you trying to solve? I've currently got two thermocouples linked up, are you trying to get more working?
    Al
    Aug 2015
    Perth WA
    461
    Sweet, someone who speaks Artisan
    No I haven't figured it out yet. Getting desperate!
    I trying to get my own recently developed Arduino module (NOT TC4) to control the Behmor heat while at the same time monitoring temps with my pre-existing 4 channel Center 304 thermometer. Both work fine separately but not together.
    I set the ET/BT COM port to my Center 304 but I can't find out where to set the COM port Artisan uses to send out it's serial commands.
    btw if I change the ET/BT COM port to that of my Arduino module, my module works but my thermocouples stop working.
    Any ideas?
    Jul 2015
    1,094
    Hmm ok, so as far as I know you can only select one device at a time in the ET/BT tab (as of course they're radio buttons) - so your approach would be to use the 'Extra Devices' tab to have your additional device working. If you select 'Center 304' under extra devices, and then click 'OK' when the 'Serial Ports Config' screen appears it has an 'extra' tab where you can change the comm port for the extra device, set it's baud rate etc.
    Does that help at all?
    I only use a TC4 with two thermocouples (and controlling my turbo oven via an ssr) so extra devices is a bit challenging!
    Jul 2015
    1,094
    That should work for you - might just be a bit tricky getting the right device to be your BT/ET values.
    Aug 2015
    Perth WA
    461
    OMG, it's kinda working.
    I've set the ET/BT to Center 304 but re-directed the COM port to my device. This is kinda working. There some extra values now being sent so I will have to adjust my code to filter it out. It also means ET and BT values are blank but I could possibly live with that.
    I've then added another Center 304 as an extra device and set it's COM port and that seems to work. I need to rename these to ET and BT. I say seems as this testing is on my desktop PC not my roasting laptop outside.
    But..........I've tried adding in another device (Center 304_34) which is needed to pick up the 3rd and 4th thermocouples of the Center 304 but it won't allow me to set the COM port. Any idea why?
    BTW, what's controlling your SSR, a potentiometer or Artisan?
    Jul 2015
    1,094
    I'm a bit confused - so you have 3x Center 304s?
    It's strange that the one that you've put into ET/BT doesn't give you the ET/BT values. I think that when you add extra devices, you have to scroll to the right and check if there is the 'LDC1 and LCD2' checked on. If so, maybe that is overriding the ET/BT use of those LCDs. Uncheck them and see if that works to give you your ET/BT values back.
    Sorry this is a case of the blind leading the blind a little bit. Their documentation is really crap for how powerful the software is.
    Artisan is sending commands to the TC4 and the TC4 is controlling the SSR. It's a bit of a bummer that way, cause likewise when I receive info from the TC4, all artisan does is poll it for details. When I was using Roastlogger earlier on, the TC4 was merely the go-between to the software, so Roastlogger was receiving all the data and was doing all the work of filtering values etc. Gave me much smoother curves.
    The reason I went to Artisan was for it's PID functions, which at the time weren't available in Roastlogger. Now that I'm only using the PID to get to a preheat temperature and roast up until the TP, at which point I change to power level control anyway, I'm tempted to switch back to Roastlogger. But it's been a while.
    Jul 2015
    1,094
    Ooh just realised they've released a version 1.0!
    Aug 2015
    Perth WA
    461
    No only one Center 304 but to get all 4 channels you need to need to add it as 2 devices, once for the 1st two channels and then a second time using the Centre 304_34 device option to get the other 2 channels.
    I'm starting to suspect that Artisan only sends serial commands down the ET/BT COM port. So my work around is attached my device to that COM port and then add the Center 304 as added devices. I've arbitrarily selected Center 304 as the ET/BT device only cause there is no option for DIY Arduino modules . The issue with this however is my device doesn't means any temps so ET and BT have to be manually reallocated to the additional devices. Not yet sure what the implications of this might be wrt Artisan profile analysis.
    When starting out I looked at Roastlogger but went with Artisan in the end. Don't recall why. Are there much advantages? Both seem to have a good following though as you say, the Artisan documentation is shite! Ah the joys of open source software.
    I've briefly looked at PIDs but not sure how or even why I'd need it for roasting. Maybe use it to control ROR rather than an actual set temperature???
    Do you use any of the Artisan's alarms to semi/auto control the roast? I'm looking at giving that a go.
    No didn't know there was a new Artisan version. I'm currently on 0.9.8 so can't imagine there would be that much difference.
    btw, thanks for the help, couldn't have done it without you. Also saves me having to buy a TC4.
    Aug 2015
    Perth WA
    461
    ok, as future reference in case anyone has this issue in the future.
    Yes Artisan can manage multiple devices but set up is a bit tricky. You either need to add "Extra Devices", use "Symbolic Assignment", or setting the main ET/BT device to different COM port. Takes a bit of mucking about to get everything talking.
    Serial commands are only transmitted on the main ET/BT com port (for now). So if you plan to control your roaster via computer, your interface device must be connected to this COM port.
    You can map temps being captured by other devices to ET and BT by using the Symbolic Assignments. Useful if like me, your interface device is separate to your thermometers.
    And there is no real centralised Artisan support forum but there is an active mailing list. Replies are prompt, just make sure your spam filter isn't blocking it.
    Aug 2015
    Perth WA
    461
    Quote Originally Posted by readeral View Post
    TrieditandWFTmyspacebarnolongerworks???helpppppp
    Aug 2015
    Perth WA
    461
    Ok, space bar working now, that was weird. Anyway the serial commands on 1.0 are really slow, like instead of taking 1-2 seconds for my Arduino to receive slider values, it's taking 10-15.
    And seems Artisan is opening and closing the COM port every time it sends a serial command. This is causing my Arduino to reset itself every time. Workaround is a grounding the reset pin with a 10uF cap. However the cap needs to be removed every time you want to upload a new sketch.
    Jul 2015
    1,094
    Gosh, ok so avoid 1.0 then. That's a worry.
    Glad you got everything working! I was going to point you in the direction of the mailing list if you weren't able to work it all out yourself, but you got there AND found the mailing list. Nice work
    Aug 2015
    Perth WA
    461
    To be fair version 1.0.0b3 is still in beta testing. I've solved the slow serial commands and COM port issues but there are other issues like it randomly crashing for 30mins.
    Anyway, I managed to do my first semi-automated roast today. Computer controlled up to FC and then over to manual. Sweet!
    Mar 2007
    198
    Do you guys know if artisan can use heatsnob? I tried but with no recognition.
    Jul 2015
    1,094
    Not out of the box. Someone reverse engineered it though and posted about it on this forum.
    Aug 2015
    Perth WA
    461
    This is correct. Artisan doesn't accept HID (human interface device) which is what the headsnob is. But someone with much more brains than myself figured it out via writing a program or reprogramming Artisan or something like that. Not easy but it's possible.
    My advice is choose your roasting software first and then buy the appropriate thermometer to match.
    readeral likes this.
    Mar 2007
    198
    Thanks....
    the cs software does everything I need anyway. Was just interested in trying somthing else.
    May 2007
    26
    I am low on the tech side of this but is the Yocto an HID? I put one on about 8 months ago, I think it was the first thing ever that worked so smoothly and seamlessly with any monitoring software, In Artisan it has dedicated setup
    Aug 2015
    Perth WA
    461
    Don't think it is. The Artisan documentation, as poor as it is, does say it doesn't recognise HID devices "for various reasons". My Center304 was also plug and play, but only after I bought a $70 usb cable >
    Oct 2017
    4
    I've just loaded v1 for new hottop pc has full control on mac except the heater and fan, anyone any ideas ? very new to this but going in full on to learn quick
    Coffee Nut fg1972's Avatar
    Jan 2012
    443
    Hello and welcome Paolo,
    When you say pc has full control but not heater and fan, what do you actually have full control of?
    Can you provide a bit more info please?
    Is the heater and fan control connected to OT1 and OT2 respectively?
  23. #23
    Oct 2017
    4
    fan and heat controls for hottop artisan v1.1.0
    sorry, well motor on off ok , stirrer on off ok , door open close all good....just the slide controls do nothing to the temp. All temps read ok . I am on mac 10.12.6 gone through random settings via the net , understand some of it , nil help from shop, suppose its more a pc thing but it was $660 more for usb . getting desperate .....fan no control either
    Last edited by Paolo68; 16th October 2017 at 11:52 AM. Reason: missed information off
  24. #24
    Senior Member DavidW1960's Avatar
    Jan 2012
    Kariong NSW
    545
    Behmor Coffee Roaster
    Hmm. I'm using Artisan running on a Raspberry Pi3. It's running v1.2.0 now. No problems controlling everything and have it automatically controlling the roast from start to finish via alarms. Hottop 2k+
    Was really pumped to get it running on the Pi. I'm running Raspbian Stretch (latest version on the Pi) and the Artisan is built for Jessie but it installed and runs perfectly. Very consistent roasts year round. I'm triggering the control via been temperature.
