Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By shrubbface
  • 2 Post By JojoS
  • 1 Post By whykickamoocow
  • 1 Post By artman
  • 1 Post By nathanharley
Thread: Behmor Temp Drop
    Member nathanharley's Avatar
    May 2015
    Perth
    68
    Behmor Temp Drop
    Every roast I get a nice ramp up, then a rapid temp drop, is this normal? I'm not sure if it's the fans turning on or something, bit it prevents me from being able to have a consistent ramp up?
    Would love some feedback from other Behmor roasters!
    Oct 2014
    27
    Its likely the after burner kicking in which happens around the 7minute mark from memory for 400g setting roast. As to whether it should drop that much or how to avoid it, that's another question.
    nathanharley likes this.
    Dec 2011
    PRL
    2,382
    Quote Originally Posted by nathanharley View Post
    Where are your thermocouples positioned? What profile are you using on the Behmor? If you are using P2, for instance, the power will drop for 100% to about 60%, after 60% of the planned roast time has elapsed.
    May 2015
    Perth
    68
    G'day Barry, using any profile, this particular one is manual mode p5. Thermocouple top left as per instructions.
    Cheers mate!
    Jan 2014
    Discovery Bay, Hong Kong
    254
    Temp drop is expected when the afterburner kicks in. Try not to fuzz too much about it. Behmor users with bean temp probe have reported that the bean temp drop is negligible at this stage of roasting.
    LeroyC and nathanharley like this.
    Dec 2011
    PRL
    2,382
    Quote Originally Posted by JojoS View Post
    Yep. This.
    Jul 2015
    27
    I had the same thing.
    Adjusted temp probe to inside the drum... it continues to rise really nicely, so don't fear- bean temp increasing nicely the whole time.
    Senior Member artman's Avatar
    Jun 2006
    2,216
    Grab a bead probe and measure bean temp. Pretty easy to do.
    I'm not sure you would get much valuable info measuring air temp?
    May 2015
    Perth
    68
    Behmor Coffee Roaster
    Cheers guys, reassuring to know that the bean temp isn't rapidly dropping. Appreciate the feedback!
    Nate
    LeroyC likes this.
