Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Andy
Thread: Roast Monitor Scales on Y and X axes
    Aug 2017
    2
    Hi All
    Is it possible to include scales on the Y (Temperature) and the X (time) axes?
    Dec 2004
    Earth!
    14,560
    If you're talking about this Roast Monitor they're by default already there and are configurable via the preferences.txt file.
    Java "Say what?" phile
    Toys! I must have new toys!!!
    Mar 2004
    Internet
    15,810
    Blog Entries
    1
    Yeah, what he said!
    Added to that...
    Using the default configuration the time is 0-30 minutes and the temperature is 0-300C
    Each small square is 1 minute wide and 20C high.
    Each bolder square is 5 minutes wide and 100C high.
    With use it's really easy to look and see 3 x bold wide (=15min)
    Aug 2017
    2
    Thanks for the reply. Would it be possible to have actual numbers at the X and Y axes displayed For example X-axes 1min, 2min and so on OR at the Y-axes 20C, 40C and so on
    Mar 2004
    Internet
    15,810
    Blog Entries
    1
    Behmor Coffee Roaster
    Don't think it will ever happen.
    Early prototypes of the software had it and it was way too messy and cluttered, even worse on small "netbook" screens that had trouble with overlapping.
    You have live number for the temperature and time under the graph, and as I said, with enough use the squares are pretty obvious.
    DesigningByCoffee and Dimal like this.
