Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By Yelta
  • 1 Post By poddypod
  • 2 Post By poddypod
Thread: Coretto over-heat cut-out.
    Nov 2006
    Banksia NSW
    14
    Red face Coretto over-heat cut-out.
    Hi All,
    Just wondering if anyone can point me in the right direction.
    I have a couple of Breville bread makers that need to cool down before they start their second batch and even (rarely) stop in mid cycle due to over heating (which of course means that if Iím not on the ball, I burn that batch).
    What I want to do is disable any heat sensor component on the circuit board . Iím never going to use them for any thing other than stirrers after all.
    Senior Member artman's Avatar
    Jun 2006
    2,289
    If you are electrically inclined/approved you can just rig up the motor to the cord via a switch and all it will do is spin the beans.
    Otherwise look for the temp sensors and move them away from the areas of heat (disconnecting might cause an error?).
    Aug 2008
    Millthorpe NSW
    2,003
    Welcome poddypod
    It’s always worth a little scroll through or a search - had a similar query not long ago
    Should find some answers here ...
    http://coffeesnobs.com.au/home-roast...tml#post619576
    Cheers Matt
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,140
    Exactly, I bypassed/removed the electronics on a single loaf Breville and connected directly to the motor about 10 years ago, not difficult.
    However if you need to be walked through the job forget it, pay an electrician, 240 volt in there! it'll kill ya.
    Dimal likes this.
    Nov 2006
    Banksia NSW
    14
    Incompetent :-(
    Yes, disconnecting did cause an error. Reckon Iíll have to get an electrician to help out. Not that confident . Thanks very much for your advice, Artman.
    Dimal likes this.
    Nov 2006
    Banksia NSW
    14
    Behmor Coffee Roaster
    Thanks, Yelta. That is the sort of advice I actually need. Not keen to roll the dice
    Dimal and Yelta like this.
