Results 1 to 14 of 14
Like Tree8Likes
  • 1 Post By Arcade
  • 2 Post By Yelta
  • 1 Post By greenman
  • 1 Post By WhatEverBeansNecessary
  • 1 Post By Arcade
  • 1 Post By simonsk8r
Thread: Post-roast protocol
    Senior Member Arcade's Avatar
    Dec 2013
    140
    Post-roast protocol
    After my roast, I blow off the chaff, then scoop the beans into a stainless weighing tray. Then I clean my stuff and put the next batch on. By the time I get back to the roasted beans it's about 15min, and they're cool to touch.
    At this point is it ok to put them in my Friis coffee container, or should you let them air/dry for longer?
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,849
    Once you've finished roasting cool the beans as quickly as possible and bag them whilst still quite warm.
    Sounds like you need to build a bean cooler, simple and cheap, 15 mins is quite a while to cool down, with something along the lines of the pic below you can have them cool enough to bag within a couple of mins, air is the enemy of fresh roasted coffee.
    There is a bathroom exhaust fan mounted in the 20 litre bucket, very efficient.
    May 2007
    Perth, Western Australia
    3,088
    Agree with Yelta, cool as quickly as possible. The exhaust fan and bucket is an effective and quick method of cooling. Leaving the beans sitting for 15 minutes they will keep roasting during the cooling process!!
    Yelta likes this.
    Dec 2013
    140
    I'm using a green bean roasting machine which has a cooling phase in the roast profile, so when I say 15min, I mean I don't check them until that time. They're probably cool in a couple of mins to be honest. Just wasn't sure if I should let them in the air to expel any CO2 or if containing them asap was best practice. Cheers!
    Jun 2009
    Moonta SA.
    5,849
    Quote Originally Posted by greenman View Post
    They certainly will.
    Jun 2009
    Moonta SA.
    5,849
    Quote Originally Posted by Arcade View Post
    Bag ASAP, air is the enemy, CO2 is fine.
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    413
    Agree with Yelta & Greenman, bag them as soon as the are cool enough to handle. Bags with a one way valve are great to use as the degassing CO2 can escape. I picked up a bunch and reuse them for maybe 4-5 times over a month or so and then use a new one as the old one gets tired.
    Dimal likes this.
    Dec 2013
    140
    Thanks guys. It’s all these incremental changes that make such a big difference to the result!
    Dimal likes this.
    Feb 2014
    Adelaide, S.A.
    178
    Quote Originally Posted by WhatEverBeansNecessary View Post
    Where did you get your bags from REBN?
    Cheers.
    Apr 2017
    Adelaide
    413
    BeanBay sells good ones, but I got mine from ebay. They are plain black, foil lined with a one way valve that you can vacuum seal. The vaccum seal is great if you have one, as I often give a couple of bags to friends/family and know that they will travel interstate with with them.
    Just make sure you get something that has a ziplock (or at least air tight) and is foiled lined. There are some on ebay that are paper only and paper with foil lining. There are also a lot with clear plastic one side which I wouldn't recommend as coffee can be sensitive to light.
    bigdaddy likes this.
    Oct 2016
    Central Coast NSW
    232
    My vote is remove when roast done (behmor, I don’t use cool cycle to cool beans) then straight into my high tech bean cooler that cost $41 I find that I can cook the beans in a minute and get more consistent roasts then letting cool I’m roast cooling cycle.
    Also a vote for the bags on beanbay
    Jan 2014
    The Dandenongs
    607
    Morning all.
    Mb21. Could tell me how you get the coffee out of the roaster when it's hot?
    thanks.
    Oct 2009
    Geelong
    658
    Quote Originally Posted by shortblackman View Post
    Morning all.
    thanks.
    Not to butt in, but pretty much butting in hehe, with my Behmor I hit cool and open the door fully. I let it cool for about 30 seconds, then push off, put on some handy oven mitts, and just take the drum straight out. Pop off the lid and pour beans straight into my sieve thing. No burnies
    Quick edit! And yes of course after I take the drum out I quickly hit 'Cool' on the Behmor again XD
    Dimal likes this.
    Oct 2016
    Central Coast NSW
    232
    Behmor Coffee Roaster
    The same as me, thanks Simonsk8r. It blows a bit of chaff around when you open the door and pull the chaff tray out but as I roast in the garage it’s no issue I just sweep or vac it up. If you find it hard to get the drum out while it still turning you can quickly turn Behmor off, pull drum out and turn cool cycle back on.
    Roasting bench nearly complete. Needs a coat of paint but rather buy more greens
