Results 1 to 5 of 5
Thread: !!!PRESUMED TAKEN!!! - Sunbeam 6910 for parts
    Jul 2012
    124
    Hi all
    I tried to pass this on a while back but got too busy. Just tripped over it again so back up it finally goes. Free to good home its more than likely repairable - just doesn't heat up so probably a thermal fuse thats gone.
    Pick up from Lower Central Coast NSW with an option of Sydney North Shore depending on work.
    Message it interested.
    Rbn
    Nov 2010
    Southland NZ
    403
    Goodness, if it is the thermal fuse that is about $50.00 or less at a repair shop. I have had two go on my machine.
    Pity I wasn't closer, I would be there before you advertised it!
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,714
    Could also be the thermoblock.
    Apr 2007
    367
    do you every find yourself on the northern beaches?
    Nov 2017
    133
    Post me a front leg? And a pf? Or both if you have, pump too...I see the flow meter is same as one in my delonghi, as is the pump...
    I have one here apart on the bench. Has leaks here and there, cross threaded fittings into plastic and such. Grrr.
    Still probably a better machine than my 800es.
    I don't really expect you to split it up, but never know.
    Pull cover off, and measure element resistance. It should have 'some' and not 'none'.
