Results 1 to 4 of 4
Thread: Sunbeam EM5800, parts needed, please help
    Feb 2009
    2
    [img][/img] Sunbeam EM5800
    I need the thermostat and in line temp fuse. the 2 white wires pulled out and allowed the unit to over heat. the board is still good.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Sunbeam EM5800, parts needed, please help
    I have a couple of OT fuses off some old Sunbeams... But do not have a EM5800 so am unable to identify or provide the missing item ??
    Pm me if you need the fuse...
    Tassiebean Phil_Jones's Avatar
    Feb 2009
    67
    Hi,
    If this is the usual sort of over temp fuse that you see in heaters, hair dryers, etc, etc, then they are readily available from Jaycar, Tandy, Dick Smith, etc (well, at least one of these will have them), else you can always buy mail order from Farnell. Usually the fusing temperature is written right on it e.g. 117 oC, along with a voltage rating. They dont come in every possible temp, but you should get one quite close.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 675F5E5B687D58595244370 link=1233820242/2#2 date=1233828684
    Hi,
    The temp on the SB units that I have seen are 187C, 216C and 227C
  1. !!! Presumed Taken!!! - Sunbeam EM5800 - Good for Parts or Repair
    By rhyskingston in forum Paid Forward - Taken
    Last Post: 12th June 2013, 03:53 AM
  2. !!!GONE!!! - Sunbeam EM5800 x2 (suit parts / repair)
    By fishotodd in forum Paid Forward - Taken
    Last Post: 21st September 2012, 09:31 PM
  3. Parts for an EM5800 - help wanted.
    By Saambo in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 24th December 2008, 07:31 PM
  4. !! WITHDRAWN !! Sunbeam EM5800 #PARTS#
    By Coughy in forum SOLD
    Last Post: 13th February 2008, 02:10 PM
