Results 1 to 5 of 5
Thread: Dry puck from pressurised baskets?
    Dec 2007
    921
    Was using my father in laws machine at christmas which had pressurised baskets and I was always ending up with a sloppy puck. Is this normal for these types of baskets? If not what was I doing wrong? (BTW I was using fresh beans freshly ground)
    Did a quick search but couldnt find a thread (I assume there is one discussing this)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Dry puck from pressurised baskets?
    Quote Originally Posted by 2C222F203721204E0 link=1235160679/0#0 date=1235160679
    If using pressurised baskets U will need to grind course and tamp hard... If too fine you will get sloppy pucks.
    Dec 2007
    921
    Thanks I hope I will never have to apply that knowledge, but a handy thing to know.
    Jul 2008
    Port Fairy
    2,993
    Part of the sloppy puck thing is the actual pressurised bit of the basket not letting the leftover moisture drain past it unlike a normal basket. Also unless soaked and cleaned well I understand they can clag up with fines and cause problems.
    BTW My Solis came with Pressurised baskets to start with (only used them for a few weeks) and I found I could get as good a result with them with stupormarket preground or ground freshroasted to "look at" in the cup as far as fake crema goes. But the fresh ground tasted so much better :)
    Mar 2009
    14
    Quote Originally Posted by 48676E6C7B446867686E6C646C677D090 link=1235160679/1#1 date=1235167945
    If using pressurised *baskets U will need to grind course and tamp hard... *If too fine you will get sloppy pucks.
    Cheers for that bit of info, Ive been wondering whats been going wrong since I bought my 800es (3 weeks ago), non pressurised baskets are on the way
  1. Conventional v pressurised baskets
    By John_Leddy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd June 2010, 06:17 PM
  2. em4800 non-pressurised baskets??
    By mmmcoffee in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd July 2009, 05:36 PM
