Results 1 to 2 of 2
Thread: Leaky wand on Sunbeam 5800
    Mar 2009
    1
    I have a Sunbeam EM5800 for the coffee club at work, which we have had for 4 years or so. It has served us well, but now whenever anyone makes a coffee the steaming wand leaks water(as many of these machines do). It has progressively got worse, to the point where water will not flow thru the group head at all. The coffee holder has been modified to be non pressurized, so it is not blocked. I have had the machine back to be repaired and are told the parts are not serviced by Sunbeam.
    I am happy to repair it myself, if it is simpl [smiley=undecided.gif]y a case of changing a seal, or O ring. (I successfully repaired a leaky thermoblock on my machine at home)
    If it is not repairable, what is the best replacement with a budget of $600 ?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Leaky wand on Sunbeam 5800
    On the ones I have seen / worked on....
    Usually a symptom of scale build up, and thus clogging the change over valve ..
    A de scale sometimes works but the build up at this stage is usually bad enough that only a strip and manual clean works... And then only for a short time... As the surface of teh valve and pipework has become pitted and attracts the buildup.
  1. Sunbeam EM 5800
    By kcl in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 23rd February 2011, 07:54 PM
  2. Sunbeam 5800 extraction time
    By Bubbacullen1 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 13th May 2010, 12:08 PM
  3. Need new filter cup handle for 5800
    By ielgey in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 23rd October 2009, 09:58 PM
  4. Ants! (and some internal 5800 photos)
    By Matt_King in forum Brewing Equipment (non-machine specific)
    Last Post: 17th May 2006, 09:14 AM
  5. is the sunbeam 5800 a decent machine?
    By ezzy in forum Brewing Equipment (non-machine specific)
    Last Post: 12th May 2006, 09:38 PM
