Results 1 to 11 of 11
Thread: em4800 tamper size
    Mar 2009
    Redlands,Queensland
    652
    em4800 tamper size
    hey guys a friend has a Sunbeam em4800 and I want to get him a tamper for it, does anyone know what size PF they have/what size tamper it needs??
    Cheers.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: em4800 tamper size
    Quote Originally Posted by 6C6C6C626E67676464010 link=1240060197/0#0 date=1240060197
    Cheers.
    Depemds on the PF basket he intends to use..
    The standard SB is close enough to 51mm and if you use others, they may/could have tapered sides..
    Mar 2009
    Redlands,Queensland
    652
    Rhanks Anger!!
    Hes just using the standard baskets so its a 51cm size basket??
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 6D6D6D636F66666565000 link=1240060197/2#2 date=1240066095
    Rhanks Anger!!
    I home that is mm and not cm... If it is 51cm then that must be a bugger to tamp
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 6B444D4F58674B444B4D4F474F445E2A0 link=1240060197/3#3 date=1240100533
    I home that is mm and not cm... *If it is 51cm then that must be a bugger to tamp
    A hydraulic press should do the trick... ;D
    ...he must also own some really big coffee cups...
    Jan 2009
    19
    A potential bottled coffee maker by the mass? :P
    Mar 2008
    466
    Feb 2009
    North Rothbury, NSW
    1,104
    giggled like a schoolgirl ;D ;D ;D ;D ;D
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Tim the toolman coffee production, yeah ::)
    Jan 2009
    19
    Pours too fast.
    I had a laugh!
    Mar 2009
    Redlands,Queensland
    652
    I had a laugh yeah thanks guys!!! hey at least you can do lots of espressos all at once, no need for waiting!! I had a laugh ;D ;D
  1. Tamper size and weight
    By smd100 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd January 2013, 05:59 PM
  2. Tamper size...does it matter
    By ajohnc in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd August 2011, 06:04 PM
  3. Krups basket in EM4800... and tamper Q
    By OzSpeedway in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 30th March 2009, 06:31 PM
  4. What size tamper to buy?
    By fierysport in forum Brewing Equipment (non-machine specific)
    Last Post: 5th August 2007, 10:26 PM
