Results 1 to 4 of 4
Thread: Filter basket conversion to unpressurised advice required?
    Feb 2009
    275
    Many of the postings I have come across, advising on conversions from pressurised to unpressurised functionality, suggest radical metal removal from the baskets lower skin.
    I have enlarged the exit hole in the double shot pressurised filter basket (Breville Cafe Roma) using a pistol drill, was very easy.
    How big does the exit hole need to be, for appropriate non-pressurised function etc?
    Can anyone offer sound guidance either evidence based or theoretical as to a satisfactory size range for this exit hole?
    Nov 2006
    224
    Re: Filter basket conversion to unpressurised advice required?
    I drilled out all of the indentations under the cafe roma basket on mine. This left me with approx a 1cm square perforated section.
    I think i used a .8mm drill bit
    One hole did not reduce pressure by much.
    Try blowing air through it - you will see what I mean.
    Feb 2009
    275
    Somehow I finished up with the same question posed in 2 spots, PL and Mokka responded with A1 advice, thanks Guys.
    Quote Originally Posted by 69505A5A56555675584D4D5C390 link=1241958773/1#1 date=1242001991
    I drilled out all of the indentations under the cafe roma basket on mine.This left me with approx a 1cm square perforated section.
    Try blowing air through it - you will see what I mean. *
    Quote Originally Posted by 32282C2E2F2C242D23410 link=1197963857/34#34 date=1242014264
    Or if you are very careful and the basket and lower (pressuirised section) will not separate, then you can simply drill a hole (about 5-8mm bitt) through the small pressurised hole. This is what I did with a Brevile Cafe Roma basket. Just be careful not to drill all the way through the filter!
    Simon
    The first enlargement of the exit hole (previously drilled) was too easy so I thought just enlarge it to about 7mm would be quick and easy (exit hole/s with a similar cross sectional area to the sum of the filter holes seemed reasonable).
    Well not quite so, but eventually finished with a satisfactory result.
    The main difficulty was that drilling the very thin unsupported metal caused it to deform readily away from the cutting edge of the drill bit.
    If I did it again, I think Id drill multiple fine holes.
    Thanks Mokka and PL
    Kind Regards
    Lindsay
    Nov 2006
    224
    Yeah. You need a really sharp bit to drill stainless (or any metal when its that thin really) otherwise you just deform it like you found out.
    I had the slight advantage of utilising a drill press. But even so, I still made a few dents in the filter - they didnt go through it though.
  1. Changing filter basket to a unpressurised one. Help.
    By anuyadav in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd October 2011, 08:56 AM
  2. Is this a Pressurised or unpressurised filter??
    By og_borat in forum Brewing Equipment (non-machine specific)
    Last Post: 27th December 2009, 02:12 PM
  3. Sunbeam filter basket conversion
    By LongMatt in forum Brewing Equipment (non-machine specific)
    Last Post: 4th August 2005, 12:46 AM
