Results 1 to 14 of 14
Thread: Non-Pressureised Basket for Via venezia
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    Where can I source a non-pressurized basket for a Via Venezia?
    My daughters been using the machine with pre-ground coffee and now she is buying my EM0480 grinder. To get any improvement over what shes been used to she will need the non-pressurized double basket.
    Any help will be grately appreciated :)
    Apr 2004
    Carlingford NSW
    691
    Re: Non-Pressureised Basket for Via venezia
    Thanks to Angelo of Demeral Tamper I now know its the group handle that needs replacing - or modifying as some have done.
    Great service Angelo, much appreciated :)
    Apr 2004
    Carlingford NSW
    691
    OOPS! That should read Demaral Tamper
    Sorry :-/
    Apr 2004
    Carlingford NSW
    691
    Thank you Dean of Sibonis Coffee. *I will go with your suggestion to remove the pressure valve from the handle.
    Feb 2009
    268
    sounds like you are sorted then, happy to talk to yourself
    Apr 2004
    Carlingford NSW
    691
    Yes, all sorted.
    I just need to convince my daughter to let me disassemble her group handle ;)
    Quote Originally Posted by 333F363635350F233E3F32500 link=1244276344/4#4 date=1244443905
    I assume thats not a question, but in case it is - yes sometimes I am happy to talk to myself 8-)
    Apr 2004
    Carlingford NSW
    691
    I removed the pressure valve without any problems. Should I also have removed the black disk that is attached to the handle? If so, how would I do that :(
    Feb 2009
    268
    im unsure of what you mean but if you are taking about the plastic inside your PF then it should be ok as long as your basket fits
    Apr 2004
    Carlingford NSW
    691
    Yep, thats the bit I mean.
    The Sunbeam EM6910 had something similar in the PF and everyone recommended removing it because of the crud that collected underneath it.
    Maybe the same reasoning applies the VV ::)
    Oct 2009
    1
    Hi Rusty,
    I recently got a Via Venezia and would feel comfortable making the changes myself, but I was just wondering if you could please post what I need to do to make the required adjustments and if the black disc does indeed need to be removed.
    On another topic, what grind level on the EM0450 did you find the best?
    Jan 2008
    476
    Rusty, Remove the black disk as it creates extra pressure. Youll need to poke it out from the bottom.
    Grant. Do a search of this section and youll find detailed instructions.
    Sd
    Apr 2004
    Carlingford NSW
    691
    Quote Originally Posted by 6E707276786479787E761D0 link=1244276344/10#10 date=1255604739
    Rusty,Remove the black disk as it creates extra pressure.
    I removed mine as soon as I got the EM6910 *8-)
    Did the same for my daughters VV *;)
    Apr 2004
    Carlingford NSW
    691
    Quote Originally Posted by 2530232C3671737271420 link=1244276344/9#9 date=1255603932
    The one that gave the right poor ;D
    Sorry, I couldnt resist that ;) There is no across the board correct setting for any grinder. They all vary even between the same models. It depends on a lot of factors and experimenting is the only way to find the right setting for todays beans in the today;s weather conditions.
    Aug 2009
    78
    Grant..,this is what I did with my emo 480....start near the middle about a 10-12 and work your way up/down from there...different beans grind differently in different conditions and at different ages even...might be a little bit annoying at first but you will soon see a pattern develop and get a "feeling" for your grinder and fave beans...
  1. Talk Coffee Precision basket vs VST basket
    By summercrema in forum General Coffee Related...
    Last Post: 28th June 2013, 05:40 AM
  2. non pressureised baskets Brevile
    By Philby1981 in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd May 2010, 08:46 AM
  3. Replies: 0
    Last Post: 1st February 2010, 07:43 PM
  4. Looking for a Saeco Via Venezia filter basket...
    By Nader in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 1st February 2010, 04:27 PM
  5. Saeco Via Venezia Filter Basket
    By jptan0 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 11th September 2009, 09:45 PM
