Results 1 to 3 of 3
Thread: Non-pressurised basket from Breville 860 for 800es??
    Nov 2008
    3
    New Breville 860 with build-in grinder, it come with a non-pressurised basket, can I use it with other Breville machine, like 800es ext, any idea it will work? ::)
    Jan 2008
    6
    Re: Non-pressurised basket from Breville 860 for 800es??
    No - the BES860 filters are larger.
    The 860 is a 54mm diameter and from memory the 800 is a 50mm diameter.
    cheers
    Feb 2009
    268
    just machine the bottom off your pressurised one and volla. (not the hole bottom just the first piece
  1. Breville 800ES unpressurised basket results
    By cookychan in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 10th July 2011, 05:38 AM
  2. Un-pressurised basket to suit Breville ES800
    By styla in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th February 2010, 09:20 AM
  3. Breville Cafe Roma non-pressurised PF basket
    By BobT in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd October 2008, 07:50 AM
  4. Finding non-pressurised basket for Breville Ikon
    By hayythere in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th August 2008, 07:18 PM
