Results 1 to 5 of 5
Thread: Breville Ikon - Pump noise??
    Jul 2009
    24
    Hello fellow Coffeesnobs!!!
    Well today was my *first day of coffeesnobbery as it heralded the arrival of my brand new, Breville Ikon, found on ebay for cheap!!! WOOO!!!!! My first machine was 30 bucks from somewhere NEW so it is a pretty big upgrade for me and I love it!!!
    Anyways, I am relatively inexperienced in the ways of expresso machines (if you cant tell) and I am wondering at the loud pumping noise that my machine is making.
    I am fully aware there is a pump but it is surprisingly loud. If anyone has any light to shed on this it would be much appreciated, and any info on how to possibly dampen said noise would be helpful :)
    Thanks!
    Jun 2008
    1,520
    Re: Breville Ikon - Pump noise??
    welcome Coffeeshotter
    most small machines are fairly loud, normally i find that the pump is a fair bit quieter when under "load" that is when you are making the coffee. But will be loud when just pumping water out the Grouphead
    as for making it quite. you could try changing the surface the machine sits on. eg on a tea towel, or a chopping board wood / plastic. even a tray might make a diff. Some surfaces seem to increase or decrease some noise. I assume it is on rubber feet already
    other mods could be looked into, is the pump "rubber mounted" or surrounding it in a box inside the machine (rubber roll?) But then you may encourage other problems like heat / moisture issues? and there may not be room inside the box.
    good luck on your coffee journey :)
    Jul 2009
    24
    Thanks for the help, I will try in the morning and report on my results :)
    Aug 2009
    78
    It probably also depends on what you are calling loud?... your surroundings will affect your perception of noise too.
    My Ikon makes a series of loudish grunting/pumping noises when you start the brew cycle but I wouldnt call it overly loud...but then again I have 3 teenage sons so am able to ignore most excess noise. ;D
    Jul 2009
    24
    The tea towel seemed to help a bit, but i suppose it could be the surronds - my house is usually pretty quiet.
    Mind you I am a teenager so I should be used to these "loud noises" hehe
  1. Breville Dual Boiler Making odd noise sometimes
    By josephagoss in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st January 2013, 10:52 PM
  2. Bezzera BZ40 - Pump Noise
    By Whiplash_Willy in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st July 2012, 02:51 AM
  3. Vibiemme domobar super - Pump Noise
    By Pretzal in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 19th March 2012, 03:49 PM
  4. Will an Breville Ikon pf work on a Breville 800ES??
    By jkwa in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 18th February 2012, 01:45 PM
