Results 1 to 8 of 8
Thread: sunbeam em5900 - unpressurized basket
    Sep 2009
    8
    hi everyone my first post
    after a little looking and calling around, i have been hitting a brick wall trying to find an unpressurized basket for my sunbeam e5900.
    not really looking for huge improvements in the coffee i make, just curious to see if you can buy them for this model.
    or should i measure the existing pressurized basket and try and find something that will fit?
    thanks in advance for any advice
    wade
    Jul 2009
    74
    Re: sunbeam em5900 - unpressurized basket
    there is a place in nth melb that sells the krups baskets that fit sunbeam. or there are a few threads on people that have modded their pressurised one... but the krups baskets are only abut $12
    Aug 2009
    19
    http://coffeesnobs.com.au/YaBB.pl?num=1246845316/0
    check this thread for info. I have the same machine as you! How are you finding it?
    Sep 2009
    8
    yeah machine is good. simple to use, makes one hell of a racket though... hard to make a quiet cup in the morning.
    i decided to take the plastic plate out and make a cup that way (with the standard pressurized basket)... mistake!!! i think i nearly blew a hole in the bottom of the glass... i now know what 9 bar of pressure through a screw hole looks like!!!
    will have to do some more research
    Mar 2009
    Redlands,Queensland
    652
    there are a few different options for what to do with your 5900. You can get someone with a metal lathe to cut our the bottom, some have even used a Dremel tool and cut it out, while others have just drilled some extra holes carefully in the base.
    The other popular option is to get a 53mm Krups non pressurised baskets.
    combine a non pressurised basket with a grinder (0450 or 0480) and you will produce some great coffee!! but the grinder will make the biggest difference to your coffee.
    Enjoy the journey!!
    Sep 2009
    8
    hm sounds like a plan
    does anyone know where you can buy coffee equipment in perth?
    looking to get a new basket, tamper etc
    only places seem to be over east and online, would just like to take my group handle in for my own piece of mind, to make sure everything fits etc.
    thanks again
    Jul 2009
    219
    Dont know about stuff specifically for Sunbeams but I know Epic Espresso sells tampers etc. and they could point you in the right direction for whatever else you need.
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    does a EM5900 take a 53mm or a 51mm?
  1. where can I BUY a unpressurized basket for em3500?
    By youngchul76 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 28th December 2012, 02:50 PM
  2. Unpressurized basket for Ikon BES400 in New Zealand?
    By fraseyboy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd April 2011, 09:35 PM
  3. Which machine/unpressurized basket combo <$200?
    By scottishrambo in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 26th November 2010, 09:14 AM
  4. Unpressurized and naked sunbeam 4800
    By Azathoth in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd October 2008, 06:42 AM
