Results 1 to 8 of 8
Thread: Poor flow from Sunbeam Cafe Crema machine
    Sep 2009
    4
    Hi all, my first post :-)
    My Cafe Crema machine has been doing stirling work, but now shes a bit sick. The flow seems very slow, I get continuous drips instead of a steady flow.
    Of course this all makes for rubbish coffee. Ive been throwing it straight down the sink *:(
    Ive done a couple of descale procedures, as per the manual. I dont have any proper descale solution, I used vinegar (again, as suggested by the manual). Didnt seem to help.
    One other thing I note is that if I put the porta-filter in place and run some water through, after I switch the flow off quite a lot of steam/water comes out the bottom (into the drip try). Like it was partially blocked I guess?
    Any ideas? Is some more heavy-duty descaler likely to help?
    Cheers all!
    Caffeine Junky
    May 2009
    1,103
    Re: Poor flow from Sunbeam Cafe Crema machine
    Quote Originally Posted by 726774626F757E060 link=1253241285/0#0 date=1253241285
    Is this with coffee in the basket, or an empty basket?
    Sep 2009
    4
    Even with an empty basket to an extent, but much worse with a full one (big cloud of steam).
    Caffeine Junky
    May 2009
    1,103
    Hard to say. Could be a blockage, could be a pump problem.
    14,666
    Does it run ok without the group handle in place?
    If yes, it sounds you have a pressurised filter basket which is pretty much completely blocked with gunge...
    2mcm
    Sep 2009
    4
    Doesnt seem like it. Im not really sure how fast the flow should be direct from the head, but it seems pretty poor.
    However I also have a spare basket (the single shot one - who uses that???) and it exhibits the same behaviour :-(
    Is it useful if I take a video?
    Sep 2009
    4
    I did a video :-)
    http://www.youtube.com/watch?v=1_8rkIlVRbc
    Please let me know what you think.....
    Ill be ringing the warranty line soon. It was a christmas present last year so a little time left :-)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 54415244495358200 link=1253241285/6#6 date=1257763735
    I did a video :-)
    First thought is scale and crap buildup in any number of the lines and pump..
    Forget the vinegar... May work if ya did it every 10day or two weeks... Trying it after a few months is like shutting the gate after the horses have bolted...
    Buy using a true cleaner and letting it soak and running a few times you may get it working..
    As to warranty...... Some would say go for it... I am a little more harsh and if you have not followed a strict maintenance program.. Then regardless of a SB or any other machine... You may have well suffered the same problem..
    PS... What is the steam like ?
  1. Sunbeam Cafe Crema EM4820
    By Barchetta in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 25th June 2013, 06:01 PM
  2. Getting the best out of a Sunbeam Cafe Crema
    By Elliebee in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th September 2010, 12:50 PM
  3. Silvia poor flow
    By atsirab in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st June 2008, 09:36 AM
