Rather than open on old thread on the EM5800, I thought I would start fresh. I have a problem where during the pour, water comes out of the steam wand. It starts about the middle of the first shot, then is constant during a second shot, which seems a bit light on the pour. I have had the machine apart and suspect the seal in the steam/water valve. The seal looks fine, but you cant be sure it seals well between the assembly. The water flow through the basket seems fine other than this. I am using a Barista grinder from Starbucks. No comments please. I have tried setting the grinder a bit more course. Could it still be too fine?
