Results 1 to 3 of 3
Thread: Optimum Pressure with the Breville BES820...
    Sep 2009
    1
    Hi All,
    Ive tried different coffee, techniques... but have never been able to achieve the optimum presure with the Breville BES820. *Its always just reaching the optimum (the upper green part) pressure, but never into the middle range!
    What am I doing wrong? *Has other achieve optimum pressure? *Please share your secret ...
    Thanks in advance. *
    Senior Member Rusty's Avatar
    Apr 2004
    Carlingford NSW
    691
    Re: Optimum Pressure with the Breville BES820...
    Quote Originally Posted by 7D2C25237A480 link=1254041841/0#0 date=1254041841
    Welcome to CS :)
    Tell us what techniques youve tried *::)
    Apr 2004
    Carlingford NSW
    691
    I assume you are familiar with the reasons behind the gauge readings.
    White Zone - Ideal Espresso
    The gauge needle when positioned within the
    recommended White Zone during pouring
    indicates that the espresso will be produced at
    the ideal pressure. The brewed espresso should
    have a generous layer of [ch64257]ne textured and
    evenly coloured golden crèma.
    Green Zone - Under Extracted
    Green Zone during pouring indicates that the
    espresso will be produced with insuf[ch64257]cient
    pressure resulting *in an ‘under extracted’
    espresso. This occurs when the water [ch64258]ow
    through the ground coffee in the [ch64257]lter is too
    fast. As a result the optimal [ch64258]avour will not be
    extracted and the coffee will be watery and lack
    thick créma on the top. Possible other causes
    for under extraction are: coffee grind is too
    coarse and/or insuf[ch64257]cient coffee in [ch64257]lter and/or
    under tamping.
    Red Zone - Over Extracted
    the Red Zone during pouring will indicate
    that the espresso will be produced with too
    much pressure resulting in an ‘over extracted’
    slow. As a result the coffee will be very dark
    and bitter, with a mottled and uneven créma on
    top. Possible other causes for over extraction
    are: ground coffee is too [ch64257]ne and/or too much
    ground coffee in [ch64257]lter and/or over tamping.
    Check your grind, it may be too coarse - you do have a good grinder dont you?
    Check your dosing - you may not be using enough coffee.
    Check your tamping - you may not be distributing evenly &/or tamping with enough pressure.
  1. Replies: 3
    Last Post: 8th July 2013, 10:14 PM
  2. Breville BES820 & Breville BGC450 Grinder Concerns
    By martinhyson@msn.co in forum General Coffee Related...
    Last Post: 11th May 2012, 10:29 PM
  3. Breville BES820
    By mejico in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 11th April 2009, 11:57 AM
  4. Breville BES820
    By Paradox_of_Thrift in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th October 2007, 12:51 PM
