Results 1 to 5 of 5
Thread: Wet puck
    Feb 2010
    28
    Wet puck
    How to elimiate wet puck?
    I have Breville 800ES + unpressurised basket but still getting wet puck after the extraction.
    Or is this impossible as you need a machine with a solenoid valve??
    Dont think my entry level espresso machine has this :-?
    Although its dryer than using the original pressure basket I can see some water on top.
    10,496
    Re: Wet puck
    If I grind too fine even my machine has some water on top of the puck occasionally.
    Does it matter?
    Feb 2009
    255
    Re: Wet puck
    Overdosing helps a bit
    Tried flattening the shower screen and filling the gap behind it to reduce the amount of water left behind and still couldnt get a nice dry puck.
    Had the same thoughts about the lack of a relief valve.
    That was one of the reasons I changed to the 6910
    Quote Originally Posted by 516D706B616077626A61050 link=1266963711/1#1 date=1266965788
    Does it matter? *
    Well.... its so much nicer tapping out a dry puck
    guv
    guv is offline
    Jan 2010
    111
    Re: Wet puck
    hi styla
    I have the same machine as you with the unpressurized basket - I generally get a nice dry puck which drops out with a decent tap but occasionally I get water but not too much.
    Tried different dose and grind settings?
    If it tastes good in the cup then im happy.
    Feb 2010
    28
    Re: Wet puck
    As shawty said....its so much nicer tapping out a dry puck :)
    nonetheless it tastes great now.
  1. puck
    By tonee in forum General Coffee Related...
    Last Post: 22nd November 2010, 10:52 PM
  2. Wet puck...
    By el_cato in forum General Coffee Related...
    Last Post: 26th September 2009, 08:16 PM
  3. My First Puck!
    By PhilMac in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd May 2008, 05:26 PM
