Results 1 to 6 of 6
Thread: Leaking Machine.
    Feb 2008
    3
    Leaking Machine.
    Im currently using a Sunbeam cafe crema for a few months. It was making pretty good coffee until it started leaking. When the pressure builds just after the start of the shot it leaks around the group handle as if the seal was faulty. However, ive replaced and swapped rubber seals and cleaned out the group etc and it still leaks!
    Any suggestions?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Leaking Machine.
    Sunbeam cafe crema ??
    Like saying I have a problem with a Holden..
    Which model ?
    Jul 2008
    Port Fairy
    2,993
    I am making an assumption here that you are using the "pressurised basket" if so STOP IT NOW ;)
    Sounds like your basket and the so called crema enhancer may be partially blocked up which results in abnormally high pressures in the group which in turn is causing your leak. On some of the better machines they run a 3 way valve which will limit the pressure in the group even if this happens but in your case the pump will drop in flow a bit and just keep bumping the pressure up.
    A goos soak in Cafetto may help but throw the basket in the bottom draw and get an unpressurised one. If I am wrong about the pressurised basket then ignore all of the above ::)
    Feb 2008
    3
    Its an EM4800 machine.
    I am using the pressurised basket and thought that could be the problem too as I havent got around to replacing it yet, however ive used 3 different ones that all do the same thing.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 13000C515350630 link=1276558512/3#3 date=1276602851
    Depending on how bad you have been abusing it ;)
    Over dosing / really forcing group to lock in / holding teh group in as it tries to un wind and pop out and fine grind etc etc.... (no one ever does these mind you)...
    Then the fibre impregnated group head/collar will have split... Happens all teh time...
    They are a spare part... But so long ago since I replaced one... Not sure, but think you can replace ya self..
    Not: As it is a compound material... When you get it out,... It may not look split.. A bit of flexing and close inspection will quickly prove if it is or is not split.
    What is ya location.. Then find a Authorised Sunbeam agent and depending on why they are.. Cross ya fingers.
    Feb 2008
    3
    Sounds like a possibility as im used to commercial machines and may have been a bit hard on it. Will look into it, thanks heaps for the help guys.
  1. Leaking EM6910
    By C15CO in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd September 2011, 02:00 PM
  2. Replies: 0
    Last Post: 15th June 2010, 08:11 PM
  3. my Bezzera machine is leaking from the group
    By rider in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 6th February 2010, 09:23 AM
  4. cimbali jr leaking
    By razmoo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th October 2008, 11:15 AM
