Results 1 to 2 of 2
Thread: sunbeam 5900 replacement portafilter
    Jul 2010
    1
    I was wondering if there are other porta filters which will fit the em 5900 which dont have the little plastic insert that the sunbeam PF has?
    Jun 2010
    33
    Re: sunbeam 5900 replacement portafilter
    Hi,
    I have got the same machine. I removed the plastic thingie by undoing the screw on the other side.
    You can plug the hole with a screw / nut combination.
    I highly recomment taking that plastic thing out, because you will get nasty build up under there.
    Are you still using the pressurized baskets? (I hope not! :-) )
    Cheers!
    Malte
  1. Sunbeam 6910 Collar Replacement
    By clubbi4 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd July 2017, 06:11 PM
  2. Unpressurised Basket for Sunbeam 5900
    By zac_sa in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th April 2011, 06:10 PM
  3. Sunbeam EM0480 replacement burrs
    By oneaday in forum Grinders
    Last Post: 1st June 2010, 06:14 AM
  4. Via Venezia replacement portafilter
    By robig in forum Brewing Equipment (non-machine specific)
    Last Post: 18th May 2008, 08:58 PM
