Results 1 to 3 of 3
Thread: Via Venezia steam wand
    Sep 2010
    21
    Hey guys, im looking to get a new coffee machine and after reading some reviews the Via Venezia is looking like a good choice for entry level.
    What i am wondering is if you can take off the cover that is on the steam wand? I want to make good texturised milk for latte art and im thinking the steam wand cover might get in the way?
    Sep 2010
    77
    Re: Via Venezia steam wand
    Quote Originally Posted by 2C272225232E4D0 link=1284326676/0#0 date=1284326676
    I do believe the part youre referring to is the "Pannarello frothing device" which looks like a crazy black tube?
    The website states that it is easily removable for cleaning, so i assume its like most frothing attachments which come with entry level machines, may help some, but hinder many so just take it off.
    Hopefully there will be a demo model in store when you go to buy it and you get to have a closer inspection!
    Aug 2004
    2,312
    With the older VV with the previous type panarello (venturi assisted steam pipe) you could simply remove the outer sheath and use the inner pipe as a regular steam pipe with good results.
    With the new VV and its new or late style panarello....you CANT do this. Well you can remove the outer, but you cant use the later type inner as a regular steam pipe.
    You can however buy the old type panarello as a spare part if you wish, slip off the new type, fit the older type straight on, and use that as above (it would take you less than a minute to remove one panarello and replace with the other).
    Rgdz,
    A.
    very first CS site sponsor
  1. Saeco Via Venezia Panarello - replace with a Steam Wand!
    By CafeLotta in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 23rd June 2016, 07:39 AM
  2. Saeco Via Venezia steam wand
    By Cay23 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 13th January 2011, 09:37 PM
  3. [m]: Changing Steam Wand Gaggia Classic to Silvia Wand
    By Dimal in forum Milk Froth and Bubbles
    Last Post: 23rd April 2008, 03:33 PM
  4. Saeco Via Venezia - leaking steam wand
    By steve7 in forum Brewing Equipment (non-machine specific)
    Last Post: 10th December 2007, 04:46 PM
