Results 1 to 3 of 3
Thread: FIX sunbeam machine - possible?
    Sep 2010
    1
    Sunbeam Coffee Machine - Model is Cafe Latte.
    Pump making noise but not pumping coffee/water through.
    All else is fine with machine.
    ideas?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: FIX sunbeam machine - possible?
    Quote Originally Posted by 707D6A6261180 link=1285383270/0#0 date=1285383270
    ideas?
    Ya know how many Cafe Latte machines there are *:o
    What is the Model number ???
    In general if no flow then you have blocked something... Try running the water / pump when you have no group inserted..
    Then you will know if the blockage is the machine or the Group / basket....
    Aug 2010
    Perth
    92
    Ive had this when Ive turned the machine upside down to clean all the coffee out of the crevices. Ive read somewhere else here not to do that. Run the pump without the group handle/PF in until you get a steady stream of water. I think by turning the machine upside down you get an air pocket somewhere.
  1. So fed up with sunbeam machine
    By youngchul76 in forum Brewing Equipment (non-machine specific)
    Last Post: 24th May 2013, 10:43 AM
  2. Which machine to buy? A Sunbeam or Breville?
    By MishMash in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd May 2011, 07:03 PM
  3. New Sunbeam Espresso Machine!
    By TwIsTeD in forum Brewing Equipment (non-machine specific)
    Last Post: 16th August 2005, 04:14 PM
