Results 1 to 2 of 2
Thread: need advice re Gaggia Classic
    Oct 2010
    2
    Hi, Newbie here. I have a second hand gaggia classic, and have done a home barista course locally (respected venue).
    I just cant seem to make a coffee thats right. Im doing all the things I was taught, and we grind fresh beans each time we use it, but the coffee tastes either watery or bitter. The beans we buy are used at several local coffee shops and they taste fine there.
    Any advice on what I should do next?
    Jun 2010
    216
    Re: need advice re Gaggia Classic
    should grind to get coffee running from group slowly 20s to 30s
    also use same amount of coffee and tamp each time.
    make sure machine is warmed up well at least 5 to 10 minutes, portafilla should be hot, try brew espresso when ready light comes on, (this means its hottest temp as thermostat turns off ) , see how it taste. then try brew when ready light turns off (temp at coolest, thermostat just turn on)
    gaggia do have a wide temp swing , you can temp surf by timing from when read light goes off or on.
    you can do search on youtube to see people brewing espresso to get idea of time and volume poured.
  1. New (Second hand) Gaggia Classic for a very very low price....Advice on mods?
    By Colen001 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 21st April 2013, 10:42 PM
  2. Newbie with Gaggia Classic looking for advice
    By Penguin740 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 31st December 2012, 07:42 AM
  3. Replies: 6
    Last Post: 15th March 2012, 08:20 PM
  4. Advice on 2nd hand Gaggia Classic
    By trentwil in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th August 2010, 04:03 PM
