Results 1 to 3 of 3
Thread: Breville Cafe Roma - problem fitting group seal
    Jul 2009
    219
    I just replaced the group seal on my parents machine and now cant get it to work properly. It starts the shot OK but then makes a loud popping sound as it finds a weakness in the seal somewhere and water starts spurting out around the sides of the group handle. Anybody had a similar problem? is it fixable?
    L
    Jun 2010
    45
    Re: Breville Cafe Roma - problem fitting group seal
    Did you ensure to install the seal the right way around, and with the shower screen also in the right order?
    Another CSer used silicone.... up to you.
    Jun 2011
    37
    Yes he would have as I have just done the same thing with a Breville Roma and is does the same thing. I think the problem is the point of exit is above the seal and not that the point of contact between the filler basket and rubber. Will try some a fine amount of high temperature silicone gasket sealant, thought not too much. Let that set for about a day.
  1. Breville Cafe Roma seal
    By Wallzy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd April 2013, 02:37 PM
  2. Breville Cafe Roma seal popping
    By gdaymate in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd September 2011, 10:52 PM
  3. Cafe Roma esp6 steam problem
    By Bames in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd August 2011, 07:14 PM
  4. Problem with Breville ESP8C (Cafe Roma)
    By citrusoap in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 24th July 2009, 05:49 PM
  5. Cafe Roma - ticking loudly - problem?
    By paull71 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th August 2008, 08:46 PM
