Results 1 to 7 of 7
Thread: Unpressurised basket????
    Aug 2010
    23
    Ok I have a sunbeam cafe crema and im pretty sure it has a pressurised basket as it only has one little pin hole on the bottom. (you cant see out of all the holes). Does anyone know if a Krups unpressurised basket would fit into the portar filter?? if so would it make that mush of a difference as i have heard that the krups unpressurised basket produces little or no crema and the basket easily falls out in the knock box?
    Can anyone help.....
    Aug 2010
    30
    Re: Unpressurised basket????
    Im using a Krups basket with the cafe crema. I had to attack the spring in the holder with a pair of pliers to make it stay in when you knock out the puck. But with freshly roasted, freshly ground coffee it produces plenty of crema and you can get a proper slow extraction. If you use stale coffee, or have it too coarsely ground, no
    Crema.
    Theres a bit of a fine line with the machine between having it choke up completely and producing really quite decent coffee. But if you can dial that in on the grinder for a cheap machine it does OK.
    Aug 2010
    23
    ok thanks. so you recommend getting one?
    Mar 2004
    118
    Susan where did you get the unpressurised basket?
    May 2010
    349
    Order the ones from breville. Exactly the same size, but unpressurised.
    Nov 2010
    54
    I presume these will also work with the EM3800 Cafe Espresso?
    Nov 2010
    54
    To answer my own question....Yes the Breville BSWF100 baskets fits the Sunbeam EM3800 perfectly as well
  1. Changing filter basket to a unpressurised one. Help.
    By anuyadav in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd October 2011, 09:56 AM
  2. Changing to an unpressurised basket
    By aleisha in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th January 2011, 06:56 PM
  3. Unpressurised basket & tamper for Ikon
    By minskee in forum Brewing Equipment (non-machine specific)
    Last Post: 24th January 2009, 09:56 PM
  4. Where to buy Krups unpressurised basket (Melb)?
    By mrfurion in forum Brewing Equipment (non-machine specific)
    Last Post: 1st November 2008, 01:53 PM
