Results 1 to 3 of 3
Thread: Sunbeam EM5600 Temperature
    Nov 2010
    6
    I have a 3.5 year old EM5600 that is on its second pump (dont get me started on how long that took to get!). I replaced the pump myself and it has been going OK for 3 months or so since I did that.
    But now I seem to be suffering from poor water temperature. Ive noticed that the shots are getting weaker over the last few weeks and if I run about 40 ml through the machine without the basket the best temperature I can measure is about 70C into a preheated cup. This seems to be quite low (but I really wouldnt know what it should be).
    The machine is used daily 1-3 times.
    Is this likely to be a thing de-scaling would help and is vinegar as good as the (expensive) commercial descaling solutions?
    Anything else to try before I give up on this thing and bin it? (it has never been particularly good but it was cheap).
    Nov 2010
    6
    Re: Sunbeam EM5600 Temperature
    Forgot to say, on the de-scaling it was descaled before I replaced the pump but not since (using a commercial powdered descaler). I dont think it would be much of an issue as it is used exclusively with tank water (as that is all we have).
    Oct 2010
    146
    Try measuring the water temperature using a styrafoam cup, trimmed and pushed up around the brew head. Poke a hole in it for the thermometer etc. Youll probably get a more accurate reading. Youll also notice that the temperature will drop a number of degrees as the shot progresses. Let the machine recover for 5-10 mins before taking a second reading.
    The temp readings on my EM6910 using this process is in the mid 80s.
  1. Sunbeam EM5600
    By KayEnn in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th July 2010, 05:15 PM
  2. Help with Sunbeam EM5600
    By Mdhatter in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 18th May 2008, 06:56 AM
