Results 1 to 5 of 5
Thread: Second Hand Gaggia Carezza Silver - Is it worth keeping?
    Dec 2010
    14
    Hi All,
    Apologies if this is in the wrong category, but Im new to the site and this board seemed to be the closest to what I was looking for.
    I have recently inherited a Gaggia Carezza Silver from my girlfriends parents. Its getting quite old (still has original VHS!!! instruction video), at minimum I think its 3 years old, but likely to be older.
    It hasnt been used for an extended period of time and probably should be serviced before use. It was never serviced during the period of time it was in use.
    Im not sure how much servicing costs? But my question is, is this machine worth spending money to get up and running? Or would I be better off buying something new?
    Look forward to your advice!
    Caffeine Junky
    May 2009
    1,103
    Re: Second Hand Gaggia Carezza Silver - Is it worth keeping?
    It would only have been around $200 when new so probably not worth spending too much on. Why not just try it out and see how it works?
    Run some water into a glass and see how it comes out i.e nice and clean or full of muck?
    Rubber seals can deteriorate with time so check for leaks e.g. does water drip from the steam wand? If you cant get a good seal at the group when pouring a shot it may just need a new group gasket which should only be $10-15
    As with any machine you will need freshly roasted and freshly ground coffee for best results.
    Dec 2010
    14
    Great thanks. Yes, its the various seals that Im worried about. I would imagine without regular use they will deteriorate more quickly.
    Might give it a test run and see.
    Nov 2009
    Altona, Melbourne
    1,584
    Put some water in it and let it heat up, should be pretty obvious if it is cactus
    Jun 2010
    216
    You can replace all o-ring seals for about $10, descale the boiler, its a very easy machine to fix, give it a bit of love, keep it out of land fill, these are worth fixing.
  1. !!!GONE!!! - Gaggia Carezza
    By RedlandsDave in forum Paid Forward - Taken
    Last Post: 9th January 2013, 08:39 AM
  2. Gaggia Carezza Help Please!
    By LaurenHenderson in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th April 2011, 11:01 PM
  3. Whats a Second hand Bezzera bz35e worth?
    By bz35 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 31st December 2007, 11:57 AM
  4. Whats a Second hand  bz35e worth??
    By bz35 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th December 2007, 10:29 PM
