Results 1 to 3 of 3
Thread: Temperature of espresso water feed is creeping up on my em2300 sunbeam
    Feb 2010
    5
    I have a plastic fantastic em2300, It has done about 24 months of good service, belting out foamy espressos. (I dont heat milk with it.). But over the last 4 months I have noticed that the coffee is too hot, and getting hotter. This is not good...
    Does anyone know a way of adjusting the temperature? Obviously there are no proper adjustments, but I thought that there might be a way of doing it. I am not afraid to void the warranty and get the tools out.
    Jun 2010
    216
    Re: Temperature of espresso water feed is creeping up on my em2300 sunbeam
    Think you should try a descale if you not done regularly, scale may have built up over the thermostat / temperature sensor, try this first, if still under warranty get them to check it for you.
    Feb 2010
    5
    OK. Good idea. I will try and get to the temp sensor.
  1. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 03:16 PM
  2. Sunbeam EM6910 - Sour Espresso = Temperature Issue?
    By jaysonleow in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th March 2011, 08:08 PM
  3. Sunbeam EM2300
    By emo in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd July 2009, 09:53 AM
