Results 1 to 7 of 7
Thread: saeco via venezia steam problem
    Sep 2008
    32
    Hi,
    I had my machine fully serviced about 6 weeks ago - and its was working like new for about 4 weeks.
    But now, the steam pressure is absolutely woeful. Any suggestions about what could be causing this and how I could rectify?
    Jun 2008
    1,520
    Re: saeco via venezia steam problem
    have you tried cleaning the steam wand inside ? could there be a blockage from milk?
    Sep 2008
    32
    good idea - start with the obvious/ easy options first!!! Why didnt I think of that. (slinks off to clean nozzle ...)
    Ill report back.
    cheers
    Sep 2008
    32
    Still not good even after a clean. It appears to me as if there is just not enough heat generated and so there is only a small amount of steam produced.
    welcome to more ideas ...
    greg
    Jun 2008
    1,520
    this may seem a silly Q but your boiler is full of water right !!!
    you know how to fill it via the steam wand dont you ? to ensure its full
    dont mean to offend but..... new users can have issues
    if full then i would open the steam wand press steam and wait and see if it heats up and makes steam "try to keep it heating with the element on"
    that said i am no 100% sure on VV operation and buttons but have had a few single boilers
    Sep 2008
    32
    Not offended ... have been using this machine for many years.
    Steam starts off OK, but then drops off to mere spits of steam.
    Jun 2008
    1,520
    sound like it might have a bigger issue
    possibly around the steam thermostat or something, you might need some pro help.... give that service agent a call.
    you could check for lose wires? (but be careful; and please unplug etc 240V and all) if under warranty then leave it to the pro.
  1. Saeco Via Venezia steam wand
    By Cay23 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 13th January 2011, 09:37 PM
  2. Saeco Via Venezia stopps steam pressure mid-steam!
    By angehc in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th June 2010, 10:43 AM
  3. Problem with my Saeco Via Venezia
    By conno in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 28th August 2009, 10:04 AM
  4. Saeco Via Venezia - leaking steam wand
    By steve7 in forum Brewing Equipment (non-machine specific)
    Last Post: 10th December 2007, 04:46 PM
