Results 1 to 5 of 5
Thread: Advice on Russell hobbs coffee machine.
    Jun 2009
    214
    Hi guys,
    I have just been given a new Russell Hobbs coffee machine. It is pictured below. It has been paired with a grinder similar to the Rancillo Rocky.
    I was wondering if anyone owns one of them and can tell me some tricks to further improve it? ::)
    Also should i remove the plastic spout thing in the filter basket? :-?
    I tired to find information on here about this machine but it seems to be quite rare. :o
    Some background:
    I use to own a em6910 with the same grinder i have for 2 years. Since then i have moved and i couldnt bring the coffee machine with me. :(
    i did manage to bring the grinder which is still working perfectly ;)
    i would also like to know if someone could recommend a local roaster in my area? :P
    Jun 2009
    214
    Sep 2011
    395
    Re: Advice on Russell hobbs coffee machine.
    Quote Originally Posted by 535C474B53565344320 link=1316618640/0#0 date=1316618640
    Hi guys,
    Some background:
    Looking at the picture, it looks to be almost 99% identical to the Sunbeam EM3600/EM3800, which there is a fair number of posts regarding. Common mods seem to be single layer filter baskets (either the Krupps or Breville, or cut the bottom floor off the thing by hand) and removing that silly plastic thing in the portafilter
    Ive modded mine a bit further with a home made naked portafilter.
    Also, Ditch the plastic thing that come with it thats supposedly a tamper, Theyre near useless, you should be able to get a decent tamper to suit easilly enough. Basket size is 51mm
    Cant help you with local roasters though, Never really been to Sth Africa
    Aug 2011
    Launceston
    130
    Id have to agree, looks he same as the EM3600/3800 from Sunbeam, is Russell Hobbs now into badge engineering?
    I have removed the black plastic cover on the bottom of the PF on my old EM2300. I cut the thing apart leaving only the very small portion the screw goes into and used that to plus up the hole.* I found that a heap of coffee muck can accumulate under the cover.
    Single wall double shot basket is also important, I guess you could buy from Oz and a decent tamper, around 51mm. The 6910 came with a tamper I think.
    The 6910 is a lovely machine to use with its 58mm PF, dual thermoblock, this new machine might be a step back...
    Jun 2009
    214
    Thanks guys,
    yea it seems to be identical to the sunbeam em3800. i will try to find the proper tamper for it as well.
    Quote Originally Posted by 233C3B2331540 link=1316618640/3#3 date=1316649109
    i have done the exact thing removed the plastic black thing but just left the middle thing that the screw goes into.
    Next i wil try to find some fresh bean maybe i will check out some of the local cafes. :-/
  1. Cambridge By Russell Hobbs Espresso Machine
    By Firepower in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 15th September 2010, 10:01 PM
  2. Russell Hobbs 3 in 1 Coffee Maker
    By gyeniceri in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 25th February 2010, 08:28 AM
  3. Russell Hobbs Cafe Continental Coffee Machine
    By garya in forum Brewing Equipment (non-machine specific)
    Last Post: 14th November 2006, 06:54 PM
