Results 1 to 2 of 2
Thread: Breville Cafe Roma seal popping
    gdaymate
    My 2-year old Cafe Roma ESP8C has decided to pop and spill/spit water out from the top of the group handle. The group handle had been getting harder and harder to fit, ie I was having to turn it further to the right to get a tight fit. Ive unscrewed the screw holding the stainless steel filter (?) in place and examined the rubber seal which doesnt look too bad (though I dontknow what a new one looks like), and when I screw it back in it doesnt fit snuggly at all, in fact its very loose. Is it the seal thats the problem, or something else? Where can I get a new seal?
    Shs
    Shs is offline
    Sep 2011
    30
    Re: Breville Cafe Roma seal popping
    Certainly sounds like a standard group seal issue.
    Id replace that before doing anything else as it is probably going to fix the problem and it is a cheap fix at that.
  1. Breville Cafe Roma seal
    By Wallzy in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 3rd April 2013, 02:37 PM
  2. Breville Cafe Roma - problem fitting group seal
    By coffeelust in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 4th August 2011, 03:22 PM
  3. Breville Cafe Roma
    By Kennym in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 5th June 2011, 07:17 PM
  4. Modified Breville Cafe Roma
    By jcl in forum Grinders
    Last Post: 6th December 2007, 11:52 AM
