Results 1 to 12 of 12
Thread: Help with Krups baskets on Sunbeam Cafe Crema
    Sep 2007
    7
    Hi
    I purchased the Krups baskets that suit the Sunbeam Cafe Crema EM4800C.
    The part numbers of the Krups baskets are as follows :
    MS 0907163 - 2 Cup Basket
    MS 0925592 - 1 Cup Basket
    The two cup basket fits well into the handle, and is held in place by the clips on the handle. But the one cup basket is a loose fit mainly because the cylindrical part at the top of the basket is only about 2mm and therefore does not clip into the handle. Im thinking they sent me the wrong one basket but am unsure.
    Can someone verify the fit of the one basket or even take a photo of the one basket and post it.
    Any help or advice would be appreciated.
    Tony
    Sep 2007
    155
    Re: Help with Krups baskets on Sunbeam Cafe Crema
    Hi Tony
    I have the Krups baskets for my breville. *The single is very loose, but it still works fine!
    To be honest I only use the double as I find the extraction a lot better!
    Regards
    Andrew
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by Secksy link=1192424067/0#1 date=1192426626
    Hi Tony
    I have the Krups baskets for my breville. The single is very loose, but it still works fine!
    Regards
    Andrew
    I agree... Have only used the 2 cup unit and if I wanted a single / lighter shot I would just stop the pour... NOTE: Still dose the two cup basket correctly.
    For home use the amount of coffee saved Vs the quality of the shot is just not worth it in my opinion.
    Sep 2007
    7
    Hi Guys
    Thanks for the advice, I have only been using the two cup basket to make 1 or 2 cups and seems to work well.
    I agree the 1 cup basket is probably not worth purchasing.
    Tony
    ozz
    ozz is offline
    Sep 2007
    26
    Hi Tony
    Regards
    Andrew
    Any idea if these are a suitable fit for a brev cafe roma?
    Also where did you end up getting these from & were they expensive?
    Oct 2007
    160
    Hi Ozz!
    Take a look at the thread I started over here http://coffeesnobs.com.au/YaBB.pl?num=1193121341
    Hope that helps :)
    ozz
    ozz is offline
    Sep 2007
    26
    Quote Originally Posted by drovers-sunrise link=1192424067/0#5 date=1193690189
    Hi Ozz!
    Hope that helps :)
    Sure does, thanks mate although at $20 I think I might stick to my bastardised basket & try to mod one of the others a little nicer. It works as is so long as I get the grind & tamp pressure right but its a little bit hit & miss.
    Oct 2007
    160
    No problem. And yeah, theyre too pricey for my liking but probably worth it in the end.
    Maybe you could scout around and find a basket elsewhere for cheaper?
    Jan 2008
    1
    Hi There, short time reader, first time poster.
    First up Im not a coffee snob but I do enjoy my coffee and am striving to make the best with the equipment I have at home. *That being a sunbeam em5600 that I inherited (my first espresso machine) and I just bought a sunbeam em0450 grinder. *Scoff as many of you may, its not in the budget to upgrade for quite some time so itll have to do. *So after perusing your cool forum I was looking at getting a "normal" basket - my question is will the part numbers quoted by tonyd fit in the em5600?.
    cheers, Nick
    p.s my first love is beer - here is a great forum for any coffee snob/beer brewers who havent stumbled onto it yet. http://www.aussiehomebrewer.com/forum/
    Aug 2010
    4
    Has anyone tried the La Pavoni Europiccola Milenium double basket #MP68 in the Breville Bar Vista. *Its 51mm but looks fairly deep and may not clear the bottom of the porta-filter. *Thinking of giving it a try and doing a porta mod if it dosnt clear. Heres a pic..
    Jul 2010
    25
    Evilree, Nice looking basket. Where can you get these from/how much? I have a naked PF for my Breville/Sunbeams that Id like to give it go in!
    Jul 2010
    13
    How deep is it?, i have a sunbeam double basket but would like to try this as well
  1. Sunbean Cafe Crema - non-pressurised baskets?
    By drovers-sunrise in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd October 2012, 09:52 AM
  2. Krups baskets dont fit the Sunbeam EM3600
    By KRINGLE in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 22nd February 2008, 05:25 PM
  3. Sunbeam 4800C with Krups Baskets - fine tuning
    By saxtim in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 29th September 2007, 08:08 AM
