Results 1 to 2 of 2
Thread: Starbucks Barista Wand Replacement
    KillerQ
    Hey all,
    I was just wondering if anyone knew of a type of replacement steam wand that is compatible with the Starbucks Barista? I am looking for something with more clearance -- like the installed wand below (from the Gaggia/Silvia mod thread):
    A new arm would complete my machine, and I would be a lot more satisfied - I dont like the height restriction that the factor wand causes... The arm in the picture above would provide sooo much more room.
    Also, if I end up sticking with my factory-installed Barista wand, does anyone know of any 2, 3, or 4 hole tips that would fit this machine?
    Thanks a ton in advance,
    Matt!
    Oct 2007
    38
    Re: Starbucks Barista Wand Replacement
    im not sure about your specific machine but coffee parts have a range of different tips just be carefull when choosing 2 hole o 4 hole that theye not going to empty your steam too quickly for your machines capacity.
  1. Breville 800es Wand Replacement
    By shazza in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th June 2012, 05:59 PM
  2. Replacement Steam Wand
    By CoffeeCreator in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th September 2009, 09:09 PM
