Results 1 to 4 of 4
Thread: Krups 978 Novo 4100 (Can I make it better)
    Feb 2008
    1
    I have a Krups 978 that doesnt seem to make the greatest Espresso. I wondered if anyone has any experience with changing out the baskets or modifying it to improve results. Otherwise let me know if it is a lost cause.
    Oct 2007
    791
    Re: Krups 978 Novo 4100 (Can I make it better)
    hey mts
    i had a similar novo something and found that unscrewing the black plastic section of the portafilter helped (somewhow). it basically created a naked portafilter.
    do u have a grinder?
    do you have a tamper? if i recall, the basket is around 53mm diameter so difficult to find a tamper that fits well.
    the baskets are also a bit funny where they have little hols and also thin lines...not sure why...i would try to find baskets that only have holes and see if that helps. i discovered that i was getting squirters from the lines.
    also, check out this: http://coffeegeek.com/reviews/consumer/krups_novo_series
    cheers
    aaron
    Oct 2016
    2
    Hi there,
    how do you proceed to unscrew the black plastic section for this: Krups 978 Novo 4100 espresso machine
    [It seems like I may have got one second hand.]
    If/when you unscrew the plastic section are all other functions saved? (1/2 cups selection, used coffee grounds ejection, etc...)
    Thank you for your answer!
    Oct 2016
    2
    Anyone knows where /what to look up/ to buy a naked portafilter for this: Krups 978 Novo 4100 espresso machine
    Thanks,
  1. Getting the most out of a Krups novo 2100-962
    By T.D. in forum Brewing Equipment (non-machine specific)
    Last Post: 26th March 2014, 02:51 PM
  2. Krups NOVO 3000 baskets blown out and need replacing others that fit?
    By NRB in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th May 2013, 04:31 PM
  3. Krups Novo 3000 Procrema Model 885
    By Cavarna in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 4th October 2012, 11:11 PM
  4. Krups Novo Plus not steaming
    By Brekel in forum Brewing Equipment (non-machine specific)
    Last Post: 17th June 2006, 12:17 AM
