Results 1 to 5 of 5
Thread: De Longhi filter basket?
    May 2007
    Perth, Western Australia
    3,150
    My son has a consumer Delonghi with pressurised pf, has anyone or do you know where I could get a basket to fit the pf and make it non pressurised and improve his shots?
    May 2007
    3,150
    Re: De Longhi filter basket?
    Quote Originally Posted by greenman link=1204175063/0#0 date=1204175054
    My son has a consumer Delonghi with pressurised pf, do you know where I could get a basket to fit the pf and make it non pressurised and improve his shots?
    The basket is 50ml from from to rim. The inside of basket is 47ml--would another brands basket fit the DeLonghi? Perhaps Breville, Gaggia?
    HELP!!!!!!!!!!!!!!!
    DONT USE
    Jan 2008
    432
    hi greenman
    for a single use the breville single from the ESP4
    for a double the saeco via venezia will fit.
    you need to shave about 1 mm of the inside of the delonghi handle, this can be done with a piston hone or similar
    graham
    May 2007
    3,150
    Thanks Graham I will give it a go.
    cheers
    Trevor
    May 2007
    3,150
    I took the pf into garage yesterday and ground 1mm from inside of aluminium pf, my old Saeco Via Venezia is sitting in storeroom waiting for my daughter to move into her new home so I had a filter basket sitting there waiting. After carefully shaving 1mm away the Saeco double basket fitted perfectly into the handle. I then got my old spring loaded tamper out and ground it down to fit the basket perfectly and presto my son now has a non-pressurised DeLonghi, I now have to teach him about dose, grind and tamp and he should be producing a far better espresso.
    Thanks for the advice Graham it worked a treat!!!
    regards
    Trevor
  1. 21 mm filter basket fit
    By Graeme in forum General Coffee Related...
    Last Post: 22nd February 2013, 03:29 PM
  2. VST FILTER BASKET
    By summercrema in forum General Coffee Related...
    Last Post: 26th August 2011, 11:09 AM
  3. paper filter in bottom of espresso filter basket
    By stuartgrant in forum Brewing Equipment (non-machine specific)
    Last Post: 7th August 2008, 12:49 PM
  4. [m]: De Longhi filter basket?
    By Dimal in forum General Coffee Related...
    Last Post: 28th February 2008, 04:04 PM
