Results 1 to 15 of 15
Thread: Help! Espresso Troubleshooting and Advice
    Oct 2008
    Sri Lanka
    486
    Hi all, Im new (but friendly :))
    I come from a country that thinks instant coffee is coffee, so when I came to Melbourne I bought a coffee machine - Breville Cafe Roma (Im a poor student, ok?) :P
    Anyway, Ive been reading up and its taking me like 6 seconds to make a 25-30ml espresso - what am i doing wrong? Is it just my machine?
    I used fine grounds, tamped at the 30lbs recommended... HElp :(
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    851
    Re: Help! Espresso Troubleshooting and Advice
    Gday Tashie and welcome to Coffee Snobs.
    A question for you first, what sort of grinder do you have?
    It sounds like your grind may be too coarse, but a bit more info will certainly help to diagnose your problem.
    Steve.
    Oct 2008
    Sri Lanka
    486
    I ground it on the finest setting when I bought it at my local - thats all i know im afraid :(
    Any recommended modifications for this machine? Should I upgrade? Im getting really into this coffee thing and I think its going to be a my most expensive hobby I had a laugh
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Hi tashie
    A bit too criptic Im afraid...
    You ground it on the finest setting of what machine?
    And you bought it at your local what?
    Apr 2005
    South Coast NSW
    851
    Quote Originally Posted by tashie link=1225273616/0#2 date=1225274748
    I take it by this comment that you bought the coffee from a shop (supermarket???) and ground it prior to taking it home, this is the problem.
    Coffee is a volatile item with a chaning personality and needs to be ground immediately before use to get the best results.
    Remember these rule of 3s for staling of coffee-
    - 3 weeks after roasting,
    - 3 hours in a hopper, and
    - 3 minutes after grinding.
    These rules are flexible, but give you a good starting point.
    So, unless you live closer than 3 minutes to the shop, your coffee will be stale before you even get near your machine.
    It is often (always) said that the grinder is more important than the machine, so an investment in a grinder would be the best mod for you at the moment.
    Good luck with it.
    Oct 2008
    Sri Lanka
    486
    Sorry, Ill get better.
    I bought it at my local market - and they had a grinder, so I ground it myself on the espresso setting, which was the finest.
    I noticed something about getting new baskets - where/what should I get?
    Sorry, im such a noob. :(
    Feb 2007
    4,513
    Thats ok tashie, there is no need for apologies.
    For starters, your local market is unlikely to stock freshly roasted coffee. That, coupled with the fact that youre in a situation where you need to grind the coffee well in advance of preparing it, will contribute to the quick flow youre experiencing.
    As for upgrading, the majority here will suggest to you that before upgrading your machine, that you purchase a decent grinder (read that as, "the most you can afford"). If youre comfortable with that, disclose your budget, and Im sure youll receive lots of recommendations.
    Oct 2008
    Sri Lanka
    486
    Can I get a decent grinder for around $200? Any recommendations? I only know that i should look for a conical burr.
    Also where do I get the better baskets (non-pressurised?) for this machine? Will it help?
    Oct 2008
    Sri Lanka
    486
    Ohh, I totally forgot to say - thanks for all your help! :D
    Feb 2007
    4,513
    I think the sunbeam em0480 sells for about $180.00.
    Oct 2008
    Sri Lanka
    486
    Loved Loveys reply :D hahaha.
    Will be getting the Sunbeam in the next week if thats the best I can get for that price.
    Thanks, and keep the recommendations coming :)
    Oct 2007
    792
    the iberital challenge grinder is good value for money but new its around 300. you could search here for used ones (in the hardware for sale section on CoffeeSnobs) or that other place where a few people think its a pretty good idea to buy and sell their goods (commonly referred to here as evilbay)
    theres also the solis grinders which can grind fine enough (and google will help you modify one to help out with that)
    then get yourself some beans from any other spondors on this site (eg cupacoffee, brownbay, pinoeer roaster, coffehit, etc (on the left hand side of the page)
    cheers and let the questions flow
    aaron
    Senior Member GregJW's Avatar
    Sep 2007
    Armidale, NSW
    618
    If money is a problem, tashie, the Sunbeam em0480 (@ abt $180 if you bargain) or em0450 (same as 0480 but in cheaper casing - abt $140?) are seen as acceptable entry level espresso grinders. Similar conical burr setup as the iberital (as well as Lux and Ascaso) but inferior build quality and longevity.
    Then, get good, fresh coffee beans, learn up on this site (and others) and youll be on your way to making very good coffee.
    May 2008
    437
    Tashi, theres a good thread here on CS on the Cafe Roma detailing the adventures of several coffeesnobs with that machine, but seeing as you asked the question: upgrade! ;)
    I used to own a Cafe Roma but found trying to make it do the same as a prosumer impossible although StuartGrant has had much better success in getting longer pours.
    http://coffeesnobs.com.au/YaBB.pl?num=1205812762/0
    There are also a couple of other useful threads since that one that you can find by doing a search for "Roma" for the "last 3 months".
    Feb 2007
    4,513
    Just another thought to keep in mind tashi - a grinder doesnt need to have conical burs to perform well.
  1. Espresso Wow Troubleshooting
    By IagoDisco in forum Cup Tasting Room
    Last Post: 2nd October 2011, 11:21 AM
  2. [m]: Help! Espresso Troubleshooting and Advice
    By TC in forum General Coffee Related...
    Last Post: 29th October 2008, 07:46 PM
  3. Where in Syd to buy a new espresso machine+advice
    By speleomike in forum Brewing Equipment (non-machine specific)
    Last Post: 4th November 2005, 02:20 PM
