Results 1 to 11 of 11
Thread: Just filed away outer screen on sunbeam EM3600 pressurised screen
    May 2010
    15
    Just filed away outer screen on my sunbeam 3600. *About to go and get some more beans for my sunbeam EMO 480 (just aquired from my frequent flyer points). * Does any pros here know roughly what grind setting , I only had some pre ground coffee so I put it through grinder on ten and it was way too fine. *No water was passing through whatsoever, I was waiting for the seal to let go.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Just filed away outer screen on sunbeam pressurised screen
    Quote Originally Posted by 6E627777606B66746B627177030 link=1274915424/0#0 date=1274915424
    Some where between 0 and 25... Truly... Every machine is different.
    But start rough and work down and finer..
    Say 20 / 22 to start with... Could be any thing between there and 10 :)
    May 2010
    15
    Sweet just about to go and get some beans and start experimenting
    May 2010
    15
    Got it running sweet about 15, went a little bit finer but seems to be over extracting. Can someone correct me if Im wrong but am I looking for 26 seconds for 30 mls( does this include the crema head or the actual black liquid) There is hope for this cheapo machine yet. I am only using the double basket
    May 2010
    15
    I filed the single shot screen first and filed too much away and blew the screen in two when pulling a shot I had a laugh
    May 2010
    15
    I see tiger stripes
    May 2010
    15
    Too much caffeine for me
    10,496
    Quote Originally Posted by 6D6174746368657768617274000 link=1274915424/0#0 date=1274915424
    Never re-grind coffee.
    You can bugger up your grinder.
    The instruction book for the 0480 should have told you what setting to use as a "starting point"; 13 from memory.
    May 2010
    15
    My impatience gets the better of me sometimes, I ended up settling on 15. I was under the impression these grinders dont grind fine enough but I have plenty of room up my sleave at this stage.
    May 2010
    15
    Re: Just filed away outer screen on sunbeam EM3600 pressurised screen
    As far as coffee machine is concerned I do not see it lasting that long as it is really working pulling those long shots, although I could be wrong. It would give me an excuse to get on the coffee train and buy a used commercial machine.
    May 2010
    15
    Machine is still going strong and using freshly roasted beans pulling some excellent shots for the money.
  1. Puck sticks to screen
    By Pascopete in forum Brewing Equipment (non-machine specific)
    Last Post: 1st January 2017, 07:31 PM
  2. Sunbeam 6910 shower screen - 1mm deeper on one side?
    By lionfish in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th September 2010, 03:16 PM
  3. Removing group head screen for descaling - Sunbeam 6910
    By badge61 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd February 2009, 08:51 PM
  4. Kenya AA Grade 17+screen - $8/kg*
    By Andy in forum Knock Box
    Last Post: 5th February 2006, 08:04 PM
