Results 1 to 7 of 7
Thread: Breville 800ES + BGC450 + mod = good coffee
    Mar 2010
    9
    After a lot of reading on CS about the B800ES, I decided to take the plunge and accept one for fathers day. *Mrs willyroo snaffled one with the grinder from GG Mt Gravatt for $288 :0 :).
    I bought a bag of Di Bella coffee from Espresso Lab in Annerley - good coffee (and coffee shop) btw.
    First brew - an OK coffee. *Plenty of experimentation, always just OK to sometimes good. *So back to CS, more reading, and a vague mention of a Krups basket.
    Next steps - contact the great team @ Pullman Tampers for a Krups unpressurised basket, and a strong recommendation for a tamper as well. *That was the key...Krups basket + good tamp.
    The BGC450 needs to be set at the finest grind setting (Turkish), and you need a very good tamper to make a quite firm tamp when using an unpressurised basket.
    Oh and I bought a decent frothing jug.
    The key to good coffee with this combo is:
    This combo gives a good 25 second extraction, and a shot to rival many coffee shops.
    Cons:
    The 800ES is hard to master frothing - however you do get it in the end. *Need to start steaming in a separate cup until the water runs through and converts to steam.
    The BGC450 is a b@st@rd to clean!!
    So if you are thinking about the 800ES, you can get good to very good coffee with care and the right - simple - modifications.
    Dec 2008
    1,049
    Re: Breville 800ES + BGC450 + mod = good coffee
    Quote Originally Posted by 352B2E2E3B302D2D420 link=1293682938/0#0 date=1293682938
    25 seconds? Wow I didnt know anyone got 25s on an unmodified BCG450...
    same as the other Brevilles.
    yep! I take out the top burr, use a brush to loosen the grinds, then tip the whole thing upside down and tap it over the sink.[/QUOTE]
    I personally wouldnt recommend the BCG450 now that the smart grinder is out, and so cheap!
    PS welcome to the snobbery :)
    Mar 2010
    9
    Thank you for the welcome...
    It is a slippery slope I know :)
    Mar 2011
    2
    Ive also got this combo but still cant get any longer an extraction, with unpressurized basket and modded grinder. Am I missing something?
    10,496
    Quote Originally Posted by 4B68676E6C7B7A090 link=1293682938/3#3 date=1301074613
    Have you modified the BCG450?
    If not, theres the problem.
    Mar 2011
    2
    Modded grinder, yes. Clip removed so it can grind finer and an o ring to keep the top burr steady.
    Rbn
    Nov 2010
    Southland NZ
    455
    Just incase anyone is reading this, you need to take out the "second stop" as well.
  1. Breville BES820 & Breville BGC450 Grinder Concerns
    By martinhyson@msn.co in forum General Coffee Related...
    Last Post: 11th May 2012, 11:29 PM
  2. Breville 800ES +BCG 450- Help on making good espresso
    By famreeks in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 29th April 2011, 06:13 AM
  3. HELP! cant get a slow pour...Breville 800ES + BGC450
    By styla in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 25th February 2010, 12:08 PM
