Results 1 to 4 of 4
Thread: Sunbeam Cafe Ristretto
    Jul 2011
    1
    Hello, I am new to this forum as I have just won* a coffee machine and have never used one before.* *I am having trouble getting it to work.* I returned the original one and it was replaced with a new one, but it does not work either. Am I doing something wrong? I fill it with water & turn the power on and the "heating" light stays on for only about 10 secs.* When i press the button to make the coffee, it makes a noise but no water comes through.* Have I got another lemon or am I just being blonde?
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    Re: Sunbeam Cafe Ristretto
    I am not familiar with machine so cannot answer specifically.
    However...have you read the manual? Most dont, but it really helps to do so.
    Is water being drawn up from the reservoir? The heat may be cutting off as the machine is likely to be configured to cut out if no water is being drawn into machine as a safety feature.
    16,605
    Is this the same as the User Manual you got with your machine?
    http://www.sunbeam.com.au/media/331141/em2300_ib.pdf
    Theres a troubleshooting guide at the back of the manual.... :)
    Sep 2011
    39
    have you tried leaving it on for longer?
    i have the same machine. the light goes off way before its hot. if you tried to start the water before its hot, nothing comes out. this very fact baffles me
  1. Replies: 3
    Last Post: 3rd April 2011, 11:29 PM
  2. Sunbeam EM2300 Cafe Ristretto vs Breville Ikon
    By starie in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd September 2010, 07:10 PM
  3. Sunbeam Ristretto advice
    By coffeevic in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 24th July 2010, 08:30 AM
  4. Sunbeam Cafe Ristretto HELP
    By arts in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 10th January 2008, 11:08 PM
