Results 1 to 5 of 5
Thread: New entry level machines from Sunbeam, new Grinder as well.
    Aug 2011
    Launceston
    130
    2 new entry level models on their website.
    The EM2800 which I assume replaces the EM2300.* Unlike the EM2300 which has a single small boiler, the EM2800 has a single thermoblock.
    The other model is the Caffe Crema II (EM4820), also a single thermoblock machine.
    I reckon theyd both ship with the dual wall baskets.
    Theres also a new grinder, EM0490, looks like the EM0480 but with a small chamber to reduce static and mess. Also programmable for dose.
    Sep 2011
    395
    Re: New entry level machines from Sunbeam, new Grinder as well.
    The EM0490 has been around for a little while, But the EM4820 and the EM2800 are definitely new.
    Im guessing that the 4820 is a replacement for the 4800? I wonder what improvements theyve made to it? it appears theyve changed the switchgear somewhat, to enable it to heat up the thermoblock for steaming. and also given it a water switch, so you can use it for hot water.
    I guess the EM2300 is no more, Rest well little Ristretto, You were a fine starter machine for many
    Aug 2011
    Launceston
    130
    I didnt know the EM0490 was around, I guess its not talked about much here. I have the EM0480 and for me it does a good job, albeit, messily.
    The only reason I went to the Sunbeam site was becasue during lunch I was flicking through the junk mail and saw the new EM4820 for $209 in the Myer catalogue and thought; "Havent seen that before!"
    My little Ristretto will be put out to pasture soon too. For me its been a great little machine to learn on.
    Sep 2011
    395
    I think the reason the EM0490 isnt talked about much in this forum, is because for the same price, you can get the Breville SmartGrinder... which is a whole nother thing altogether. the EM0490 looks like the same structure of the EM0480 with a fancy funnel attachment for dispensing, oh, and timer function.
    I guess Id know which Id prefer out of the two.
    Aug 2011
    Launceston
    130
    I know which Id prefer now too.* Seattle Coffee Gear do a decent review on the Breville Smart Grinder after modifiying it with the shim kit.* In their first review they found it wouldnt grind fine enough for espresso;
    http://www.youtube.com/SeattleCoffeeGear#p/search/9/8piBChRggPM
    Might be time to save for an upgrade....
  1. old/used Saeco Via Venezia or new Breville or Sunbeam entry level?
    By follower in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 27th April 2012, 07:49 AM
  2. Entry Level Semi-Commercial Grinder
    By Prosmart in forum Grinders
    Last Post: 25th October 2011, 06:56 AM
