Results 1 to 4 of 4
Thread: Gaggia coffe deluxe and pid
    Jan 2011
    16
    I want to add PID for my Gaggia coffee so i looked on ebay and found this:
    http://www.ebay.com/itm/PID-Temperature-Controller-K-sensor-25A-SSR-20-OFF-/220870722277?pt=LH_DefaultDomain_0&hash=item336ceb c2e5#ht_6203wt_952
    I want to know will this thread on the K sensor will fit with the thread of the thermostat? Are they same?
    Oct 2011
    12
    Re: Gaggia coffe deluxe and pid
    After finding the item from the item number in the URL (broken link?) I noted the description of the thermocouple says that it has a 4.5mm sensor diameter.
    In another CS thread it says a 4mm diameter is mentioned for the thermostat hole in a Gaggia Classic (apparently "M4" size, I cant post the thread link - Im too new here and not its allowed, but its thread number 1238569278).
    I have no experience in this area so cant comment, but I thought posting the sensor diameter quoted on the K type sensor in question might help someone more experienced to answer you better :D
    Jan 2007
    2
    I have a Gaggia Coffee Delux and the thermocouple that worked for me was M4x0.70. I have an auber instruments kit and it works great.
    Jun 2010
    217
    the original thermostat uses a 4mm thread to screw into the aluminium boiler.
    xEggbert would be correct on the specs.
    I drilled a hole down the centre of a stainless steel 4mm screw to mount my thermocouple bead
    think it was about 1mm diameter and a nice tight fit.
  1. New to it all... Gaggia coffee deluxe and gaggia grinder (not sure of model)
    By kierent in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 30th April 2012, 09:20 PM
  2. Gaggia coffe deluxe and using pods
    By nikola_bb in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st May 2011, 08:13 PM
  3. PID for Gaggia coffee deluxe
    Last Post: 25th January 2011, 01:03 AM
