Results 1 to 10 of 10
Thread: Sunbeam EM4800+Breville BCG800
    Oct 2011
    4
    Hi All, I have recently purchased a EM4800 (to replace a broken Cafe Roma) and subsequently purchased a BCG800. In addition, I am using the Breville BSWF100 NP double shot filter.
    Today, I purchased roasted beans (today) from a coffee shop, however I am having no luck with this combination.
    I have set the grinder to 13 grind setting,1 shot, maximum grind amount, however it seems the pour is too fast.
    A finer grinding setting than this (say 17) results with the machine struggling with nothing more than a few drips from the PF and fine grinds in the Espresso cup. Applying a reasonable amount of tamping pressure only compounds the problem.
    Are there any settings to start from? If not,any advice would be appreciated.
    Thanks,Jeremy.
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Re: Sunbeam EM4800+Breville BCG800
    Obvious question would be did you try the grind setting at 15?
    Oct 2011
    4
    Thanks for the reply, yes I have tried it on many settings including 15.
    Sep 2011
    395
    Quote Originally Posted by 524E43544B4955260 link=1320069340/2#2 date=1320073468
    And?
    There should be some sort of progression between "too fast" through "slightly quicker then I like" to "just about perfect" right along to "Damn, its clagged the pour again"
    Unless your grinder is totally busted, you should be able to find some sort of happy medium that is close enough to the 30 second pour that has a repeatable attempt
    Only other answer I can think of is youre somehow blocking the holes in the basket by tamping too hard, which is unlikely.
    Mar 2011
    609
    I know it will end up going through a lot of coffee, but find the setting where it chokes (17 you said) then go one click coarser (in which there are 2 clicks per setting on the LCD), dose exactly the same amount (use scales if you have them) and pour. If it chokes or is too slow, go a click coarser again and so on till you find it.
    There shouldnt be a setting where one click gushes and the next click finer chokes on the BCG800, unless theres something wrong with the grinder.
    Oct 2011
    4
    Just using the "automatic shot" the grinder appears to deliver a pretty constant weight when measured on Electronic scales.
    With the goal being a single shot of 30ml in about 30 seconds (using the double basket), is a dose of around 10g of coffee a reasonable starting point?
    Senior Member dr.a.j.pickering's Avatar
    Jun 2011
    398
    Quote Originally Posted by 4F535E495654483B0 link=1320069340/5#5 date=1320150857
    Using a double basket you should be aiming for 60ish mls in 30 ish seconds and 10g sounds like a very small dose IMHO
    Oct 2011
    4
    Quote Originally Posted by 4A5C004F0044005E474D454B5C4740492E0 link=1320069340/6#6 date=1320152473
    Using a double basket* you should be aiming for 60ish mls in 30 ish seconds and 10g sounds like a very small dose IMHO
    Thanks for the info, would around 15g be more appropriate?
    Sep 2011
    395
    as far as Im aware, the "standard" size coffee dose is approximately 7 grams dry, 14 for a double, and 21 for a triple
    I know some people play with updosing and downdosing, but really, if you arent sure whats going on, Id suggest setting it so that youre getting approximately what is standard and working out from that
    10,496
    Quote Originally Posted by 3C202D3A25273B480 link=1320069340/7#7 date=1320152769
    It depends on your basket.
    Im currently using a Synesso double basket and dont go less than 16g.
    I go up as far as 21g.
    The dose (grams) is a variable.
    The grind fineness is another variable.
    All variables change results.
    Only change one variable at a time to get where you want.
    More coffee or finer grind will slow down a pour.
    Less coffee or a courser grind will speed up a pour.
    If youve exhausted all grind settings with no luck I suggest you stick to one setting and varying the dose.
    A good set of scales will help with this.
  1. Breville BES800/ BCG800 Ďversusí Sunbeam EM6910 / EM0480
    By cdill in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th June 2011, 10:11 PM
  2. Start with Sunbeam EM6910 & EM0480 or Silvia & Breville BCG800?
    By Konerator in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd December 2010, 07:15 PM
