Results 1 to 8 of 8
Thread: which 2nd hand Breville?
    Oct 2011
    16
    Im looking at a very low cost, short term upgrade and have found Breville Ikons and Breville es800s that are both sub $100.
    Im not necessarily pro Breville or anti other brands but I think these two are both good for what I want to achieve short term.
    My question is:
    If my wife and I are big latte drinkers should I get an Ikon for the boiler and thus (hopefully) more/better steam or the es800 because it appears to be a slightly higher level machine all round (if my info/assumptions are correct)?
    Any advice is greatly appreciated!
    Cheers!
    Jono.
    Oct 2011
    16
    Re: which 2nd hand Breville?
    Forgot to mention, I already have NP baskets from a Bar Italia/esp4 that I can put in these which is another reason why Ive looked at Brevilles.
    Oct 2011
    16
    Anyone? Also curious if anyone has any knowledge/experience with the Gaggia Evolution. I know the Classic has a good rep but is the Evolution, being a noticably lower price bracket, much lower in quality?
    Any opinions, suggestions, advice hearsay, scuttlebutt are really, really appreciated!!
    Cheers!
    Jono.
    Dec 2008
    1,049
    Never used an Ikon or Gaggia. I had an 820ES then a Giotto. The 820 was good for a start, however needed proper flat-walled single-floored baskets and a good grinder. IMHO the BCG450 didnt cut it, even modified.
    What Im saying is make sure you have at least the smart grinder, maybe even try it with your current machine and then you wont need the short-term upgrade? Save your pennies for when you get that Silvia or VBM... Just a thought...
    Nov 2011
    8
    Go for the Ikon, Ive used both machines. The 800 looks nice on the outside but its still a thermoblock machine and performs similar to a Roma
    Oct 2011
    16
    Thanks FB.
    Only problem is Ive now also found a 2nd hand Gaggia Evolution for the same price. Any ideas on which is better out of the ikon and the evolution? Im searching all I can but if anyone knows it would really help me out.
    Cheers!
    Jono.
    Nov 2011
    8
    Id grab the Gagia, Havent used it but reviews are generally positive and the 58mm baskets are a nice option, there are aftermarket options like a longer steam wand too.
    YouTube is a good place to check the machines real world performance also, obviously limited to the capability of the person making the video but its a good estimate.
    Oct 2011
    16
    Thanks again FB!
    From what I can gather off the Gaggia site, the main differences between the Evolution and the classic are plastic exterior instead of stainless, smaller reservoir and no 3 way valve which I didnt expect in such a low price bracket anyway.
    Cheers!
    Jono.
  1. Breville BES900 - repaired - still faulty. Breville don't care.
    By Nevin in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th August 2012, 05:53 PM
  2. Breville BES820 & Breville BGC450 Grinder Concerns
    By martinhyson@msn.co in forum General Coffee Related...
    Last Post: 11th May 2012, 10:29 PM
  3. Breville ES800 Coffee machine and Breville BCG 450 Grinder for $379, Target.
    By Ari in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 14th June 2011, 05:52 PM
