Results 1 to 3 of 3
Thread: Sunbeam EM5900 Arista - descaling problem
    Nov 2011
    1
    I have a Sunbeam EM5900 Arista espresso machine which, I have just descaled it for the first time. Once it was all put back together I tried to attached the group handle and I cant, it is like the washer doesnt fit back properly... Has anyone else had this problem and if so how did you fix it...
    Thanks in advance!
    Sep 2011
    395
    Re: Sunbeam EM5900 Arista - descaling problem
    Errr, why did you take the machine apart to descale? Usually a descale for thermoblock machines just means running the solution through the system...
    Aug 2011
    Launceston
    130
    Sounds like you removed the shower screen and seal and may not have got it quite back together the same way.* You might need to wander into a shop that sells this machine and have a squizz.
  1. Expobar minore and descaling, problem????
    By coffeechris in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th November 2014, 04:56 PM
  2. Gaggia Platinum Vogue - Problem clearing descaling indicator
    By knetix in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 31st July 2009, 04:54 PM
