Results 1 to 4 of 4
Thread: Re: Struggling with La Pavoni Puccino
    enjoy black coffee JamesM's Avatar
    Nov 2008
    Perth
    672
    how fresh are the beans? do they have a roast date?
    12-bar is quite high for espresso.. however workable. Try to keep your dose and tamp consistent and then adjust on the grinder for change. Try grinding a little courser, with a little lesser dose, and a firmer tamp. If you are getting lots of grinds in the cup, and the basket it sludgy its probably too fine.
    keep at it, practice !
    Caffeine Junky
    May 2009
    1,103
    Firstly I dont think you can rely on the accuracy of the manometer on domestic machines. That aside, if you keep getting steam coming out of the group after flusing for a minute then it sounds like it is running too hot.
    Is there any chance you have the steam switch on whilst you are brewing? If not I would be taking it back to the store. If you bought the machine from the online seller which comes up under a google search ...... good luck getting good service.
    Senior Member SniffCoffee's Avatar
    May 2010
    Canberra
    703
    Hi, if this is a single boiler machine (which it looks like it is), are you priming the boiler before pulling your shot?
    (eg for a lelit single boiler it means opening the steam valve and turning the pump until a steady stream of water comes out of the wand, then closing the valve, switching off the pump and letting the boiler heat up to temp, then pulling the shot, then steaming (and then priming the boiler again ready for next time))
    Your old sunbeam was probably a thermoblock which didnt require the boiler to be primed.
    Sniff
    Caffeine Junky
    May 2009
    1,103
    OPs posts disappear and one of these machines suddenly appears on evil bay .................... :-? :-?
  1. Car-puccino - coffee powered car
    By gregpullman in forum General Coffee Related...
    Last Post: 2nd August 2012, 08:36 PM
  2. La Pavoni Puccino PCL
    By det in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th July 2009, 10:43 AM
  3. La Pavoni Puccino PCL
    By aaronb in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th October 2008, 05:57 PM
