Results 1 to 3 of 3
Thread: EM3600 loose filter
    Dec 2011
    46
    EM3600 loose filter
    Hi all, Ive come into possession of a used EM3600- grinder is on the way, and first order of business was to get some single wall baskets. I ended up with the Breville set, and they seem to work fine.
    When I first got the machine, the standard Sunbeam basket would fall out if I tried to knock the coffee out of it. I figured this was due to the pressurized basket keeping the puck fairly wet. When I use the unpressurized basket, the puck is reasonably dry, but they are even looser in the portafilter so I still cant knock the coffee out without the filter going with it.
    Any ideas on how to make it more secure? Thanks!
    Sep 2011
    395
    Re: EM3600 loose filter
    Quote Originally Posted by 62736273757D7D6177120 link=1324338916/0#0 date=1324338916
    if you pull the basket out, Youd see a spring around the inside of the Group handle, Pull that out, and give the bends a bit more of a corner, then put it back in, Thatd fix the problem of the basket not being held firmly 99% of the times :)
    Dec 2011
    28
    Quote Originally Posted by 4D60746669686F66407547607564010 link=1324338916/1#1 date=1324379610
    if you pull the basket out, Youd see a spring around the inside of the Group handle, Pull that out, and give the bends a bit more of a corner, then put it back in, Thatd fix the problem of the basket not being held firmly 99% of the times*
    I can confirm this. I recently did it to my own EM3600 when I obtained unpressurised baskets for it; even the original pressurised baskets were loose in the portafilter from day one.
    Regards,
    Harlan
  1. Loose Rancillio Basket?
    By KidSetzer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th November 2012, 09:12 PM
  2. loose part Sunbeam EM0480
    By jimmys in forum Grinders
    Last Post: 12th April 2011, 06:07 PM
  3. confused Newbie on the loose
    By Suepergran in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 4th April 2010, 09:53 PM
  4. portafilter spout loose
    By bennett in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th March 2010, 09:32 PM
