Results 1 to 3 of 3
Thread: Timing my espresso - Gaggia Pure
    Jan 2009
    7
    Gday all,
    I just took delivery of my first espresso machine this morning - a 2nd hand Gaggia Pure.
    Im using it with my Breville Smart Grinder, and already getting results that Im very happy with.
    One question though - the more expensive machines Ive used had timed shots for singles & doubles.* This just has a pump on / off switch.
    In terms of timing how long a shots taking, what am I looking for?* The water to be coming out clear?* Something else?
    Im trying to dial in the right tamp pressure / coffee volume / grind, and its tricky without knowing what length of time its taking to pull a shot right now.
    Anyway, TIA, and thanks to CS generally for all the advice that has lead me to this point!* Ive learned a lot lurking here already, you guys are an amazing resource :-)
    Cheers!
    John
    Dec 2004
    Earth!
    16,348
    Re: Timing my espresso - Gaggia Pure
    30ml/60ml (single/double) in 30 seconds with the extraction being stopped when the stream starts to blond.
    Java "Sipping on goodness" phile
    Jan 2009
    7
    Ahh, exactly what I was after. Thanks, Java!
  1. GAGGIA Espresso Pure Vs Ascaso Basic
    By jsrenaud in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th December 2011, 10:20 AM
  2. Gaggia Espresso Pure or Breville Ikon
    By alan7948 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th August 2010, 06:35 PM
  3. Gaggia Espresso Pure.... Pure Rubbish!!!
    By Oakie in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 8th October 2008, 04:45 PM
